lock issue, need help
Old 09-01-13, 05:46 AM
russ1958
russ1958's Avatar
Default lock issue, need help
I recently purchased a 1999 Ls400. It's an awesome car, only 80K miles on it. However the driver side front door will not lock with the remote or the power button, it only works with the key. Am I looking at replacing the actuator? I've read the many posts on DIY ebay motor replacement. Dont want to go through that unless I have to.
Old 09-01-13, 12:43 PM
LScowboyLS
LScowboyLS's Avatar
with your symptoms, lock actuator is a good possibility
Old 09-01-13, 02:50 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
sounds llike actuator.
it's not locking or unlocking remotely?
Old 09-02-13, 05:44 AM
russ1958
russ1958's Avatar
No, not the driver's side.
Old 09-02-13, 10:20 AM
peterls
peterls's Avatar
I believe that if you were to lock/unlock the passenger door using the key, not the remote button, all doors should lock/unlock including driver's door. If they all do, except for the driver's one, then your actuator needs to be replaced.
On the driver's side, you'd need to turn the key toward unlock twice (towards the back of the car), quickly, to unlock all doors at the same time. If they all unlock except the driver's one, again it is your actuator that's giving you trouble.
Old 09-02-13, 03:48 PM
russ1958
russ1958's Avatar
1. I need to correct an earlier post. using the remote, all doors except the driver door do lock. But, none open with the remote.
2. Using the key on the passenger side, all doors except the drivers door lock and unlock.
3. Using the key on the driver side all doors unlock, drivers too. Can lock the drivers side with the key
Old 09-02-13, 05:31 PM
peterls
peterls's Avatar
That sounds like a wiring problem to me. Unless some of those wires go through that infamous wiring harness in the trunk, tied to the goose neck hinge, I don't know where I would start looking for problems... but if anyone was playing with the wiring due to after market installation of anything electrical (e.g. stereo, alarm, whatever), wherever they were working, that's where I would look at first.
The kind of problems that your average aftermarket installer can create can be amazing. I had a car that had problems only at certain speed, and that no one could figure out... until one smart mechanic figured that whoever installed the stereo created a little problem with ground wire that ECU was connected to, and that confused the ECU only at those certain speeds (the car was loosing power around 50mph, just as I would be accelerating on a highway, it used to drive me nuts to no end).
Old 09-02-13, 08:50 PM
Yamae
Yamae's Avatar
Sounds like a door computer is not working properly.
Old 09-03-13, 05:11 PM
russ1958
russ1958's Avatar
there is no aftermarket work. the trunk however does not unlock with the remote.
Old 09-03-13, 05:17 PM
russ1958
russ1958's Avatar
What is the "door computer"?
swat1727
03-27-24 10:31 AM
abiz181
06-25-22 03:09 PM
AfroPoker
12-20-18 08:41 AM
gsenthil
RX - 1st Gen (1999-2003)
02-19-13 03:39 AM
vinh
07-03-09 10:49 PM
Quick Reply: lock issue, need help
