DIY: All red tails using vinyl, cheap & easy
Old 08-10-13, 05:47 PM
TMAdash1
TMAdash1's Avatar
Default DIY: All red tails using vinyl, cheap & easy
Wanted to all red the tails on my recently purchased LS400, after looking at the various ways of doing this I decided to get a roll of translucent vinyl since it seemed to be the easiest and cheapest way.
After searching for a DIY I saw some for the GS and IS but nothin for the LS, its pretty much the same process but I thought I'd do a model specific one.
Tools Needed:
- a roll of translucent red vinyl. I bought mine from ebay and paid $10, now its $7 go figure
http://www.ebay.com/itm/12-x-48-Glossy-Red-Vinyl-Wrap-Overlay-Film-Tail-Lamps-Lights-Sidemarkers-/130963919832?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1e7e0ed3d8- razor or x-acto knife
- blue painters tape
- piece of paper to make a template
- spray bottle with a bit of car or dishwasher soap and water, bought one from WalMart for $0.97
- credit card
1) Lay out the painters tape where you want the vinyl to go
DIY: All red tails using vinyl, cheap & easy-l0idmdy.jpg
2) Tape a piece of paper and use a pencil to transfer the shape over, you can see in the picture below I tried to trace it but I'm pretty crappy at that so I just scribbled on the edge to transfer the shape
DIY: All red tails using vinyl, cheap & easy-klqqc93.jpg
3) After cutting out a template I traced it onto the vinyl and cut it
DIY: All red tails using vinyl, cheap & easy-ioqqyay.jpg
4) Now comes the time to apply the vinyl, after cleaning the amber section of the taillight (I used rubbing alcohol and simple green). Spray the tail light generously with the soap mixture from your spray bottle, remove the backing from the vinyl piece and spray that aswell. Spray as you peel to prevent it from sticking to itself. Place the vinyl onto the tail light and adjust as necessary, once its in place where you like it use the credit card to squeegee the soap mixture starting in the middle and working your way out. Trim the end closest to the trunk
The vinyl that I bought had a very very thin layer of cellophane on the top, you can see in the picture below that if I let the top of the vinyl get too dry while scraping it would start to tear so make sure you keep spraying it.
5) On mine I had an issue with the corner in that it kept wanting to scrunch up around it since that corner also is angled top to bottom. To solve this I just kept working it as it dried and when I got it down for the most part I put some painters tape on the edge making sure to make it as flush as I could for it to dry that way. The bubble you see below isn't actually the vinyl, its the cellophane bubbling up from working it with my fingers.
DIY: All red tails using vinyl, cheap & easy-083blb6.jpg
6) After waiting for a bit I peeled the blue tape and top layer of cellophane praying that this worked and voila, it did!
DIY: All red tails using vinyl, cheap & easy-c3wtl6b.jpg
And here is the final result, apologies I REALLY wanted to do this picture with one side red and one side amber but there was a thunderstorm rolling in so I wanted to get done as quick as possible
DIY: All red tails using vinyl, cheap & easy-gkrhwvo.jpg
All in all this whole process was pretty simple and the actual install didn't take long at all, maybe 30 mins. I tried to be as thorough as I could for any noobs out there. Surprisingly I didn't get ANY bubbles either which I'm pretty happy about, the top layer of cellophane would bubble while I was scraping it so it was kinda hard to tell if there were any until I took that off.
FINAL THOUGHTS:
- There are definitely different ways of cuttin the vinyl to the shape needed, I just used what limited resources I had at my disposal
- If I had to do this again I'd probably get some better vinyl, after reading a bunch of DIYs on other sites I found that people seem to be pretty happy with RVinyl but I didn't find this out until i already bought the ebay vinyl.
http://www.rvinyl.com/Red-Smoke-Tint-Film.html
Old 08-10-13, 06:49 PM
ItsMiles
ItsMiles's Avatar
Nice... I might go and try this soon... I wanted to do something about the taillights... Especially since I can't afford the LED ones yet...
Old 08-10-13, 07:04 PM
dc893
dc893's Avatar
I might go ahead and give this a shot since it is a cheap mod. Thanks for posting!
Old 08-10-13, 07:26 PM
TMAdash1
TMAdash1's Avatar
Ha, thats exactly why I ended up doing this I couldn't afford the LED tails
No problem, figured for my first post I'd go all out! And its completely reversible too, if you want it peels right off just might have to get some adhesive remover to get rid of the glue.
Old 08-11-13, 01:11 PM
Sc0pe
Sc0pe's Avatar
I think I might be super OCD but you can still faintly see orange. Ultimately, I think it looks really good and thank you for writing this DIY!
Old 08-11-13, 06:01 PM
dc893
dc893's Avatar
I can see a hint of orange as well. It still looks good though.
Old 08-11-13, 06:31 PM
TMAdash1
TMAdash1's Avatar
You guys are right I noticed that after I installed it. Again I think it goes back to the quality of vinyl, if it was a darker shade of red this wouldn't be noticeable.
Old 08-11-13, 08:03 PM
dc893
dc893's Avatar
Still looks good for the price!!!!
Old 08-11-13, 09:00 PM
VanCityLS4
VanCityLS4's Avatar
Got mine from Blue Batmobile pre cut for ~ $10 shipped last year. Required minor trimming & still looks great. Quality of vinyl is key.
Old 08-12-13, 03:43 PM
xtremex626
xtremex626's Avatar
been done many times. i remember posting about it in a thread. good vinyl shouldn't require water. good vinyl is like a sticker. just stick it on and lay it out using a credit card and you're good to go. that's how i did mine. the vinyl i used was $5 and a perfect match for the red.
Old 08-12-13, 10:35 PM
Sc0pe
Sc0pe's Avatar
Originally Posted by xtremex626
been done many times. i rememebr posting about it in a thread. good vinyl shouldn't require water. good vinyl is like a sticker. just stick it on and lay it out using a credit card and you're good to go. that's how i did mine. the vinyl i used was $5 and a perfect match for the red.
You wouldn't happen to remember which vinyl you used, would you?
Old 08-13-13, 06:17 AM
jcp2k
jcp2k's Avatar
Do you still have some vinyl left? Aha I'm in the 626 too maybe I'll buy some off of you
flipside12
flipside12's Avatar
I used vht red nightshades to do mine. Not only does it remove the amber but it also gove a restore to the taillights and is only 10$
Old 08-13-13, 06:10 PM
TMAdash1
TMAdash1's Avatar
I looked at using VHT but it was a lot more work and was permanent, eventually I might do VHT or get some LED tails
Old 08-14-13, 07:34 AM
TaffyK20si
TaffyK20si's Avatar
Thanks for sharing this! I JUST bought some red Rvinyl yesterday and some 3M adhesion primer to get around the corners good. Then I see this post today hahahaha. Looks really good! Can't wait to do mine in a few days.
Quick Reply: DIY: All red tails using vinyl, cheap & easy
