studio camber roll center adjusters (RCA)
Old 10-21-13, 11:41 PM
  #31
PureDrifter
BahHumBug
PureDrifter's Avatar
actually no, that is what is specified given the type of strain the aftermarket (much stronger) bolts are undergoing.
Figs for example specifically quoted me at stock + 10% for aftermarket grade bolts. so ~93-95 ft*lbs.
120 is an old number given out with some 2GS SAGE rcas which was later updated. It may be what studio is giving out to users of the camber ADAPTERS, not regular RCAs.
Old 10-22-13, 12:03 AM
  #32
Dranom
Dranom's Avatar
is studio still around? I heard Ian quit
Anyways i found some cambering rca with caster correction in japan.
Anyone ran those yet?
Old 10-22-13, 02:41 AM
  #33
samsung201
samsung201's Avatar
Thanks. For example. You mean 113NM + 10% round 126NM (93ft-lbs) is ok?
After i install the Camber and torque it to 85ft-lbs, i feel that was verry near to damage the screw thread. Maybe can imagine me...
Timmy, what can you say. How it is with your 95ft-lbs toque for now? How fast you drive? Hows your streets there? We have here big holes in the streets and im scary abt to cut the bolts when the tire ran into one of this holes.
Ah what I noticed. when I'm driving I have a loud rolling noise. Mean it comes from the tires. Is this normaly?
Old 10-22-13, 11:00 AM
  #34
bdan
bdan's Avatar
Tsuraichi!
Old 10-22-13, 11:10 AM
  #35
timmy0tool
timmy0tool's Avatar
i was PMd by ian (FULLMOONG) stating that 95-105 ft-lb is a good torque for the studio parts. he also told me he is not part of studio anymore so you are right monard. they are still around but now under kyle Kyle@bold-move.com. i torqued at 95 ft-lbs.
yeah i know what you mean samsung. torquing to 95 was scary but it got there. so far it's holding up great. i drove as fast as 105mph at one point but that was , never again will i do that! our streets are smooth in some places but where i live it's not. i drive slow since i have 225/35/19 tires in the front. and yes that rolling noise is your tires since you are riding on the side. check the tire pressure and thread every so often.
Old 10-23-13, 12:21 AM
  #36
samsung201
samsung201's Avatar
Thank you so much Timmy for all your hint! It helps me out.
I will torque it this weekend higher. We see us at VSC.
Old 06-04-14, 11:13 PM
  #37
johhntran
johhntran's Avatar
sorry to bother you on your thread, but what kind of noise exactly did your car make after the rca install? i did get shorter 45mm bolts for my gs but its making some crazy creaking noises after i installed my camber rcas. it occurs when i turn wheel even slightly, but when i turn the wheel back and forth rapidly it will not produce any noise. ive ruled out tie rods and lower ball joints because theyre new.
Old 06-10-14, 04:38 PM
  #38
timmy0tool
timmy0tool's Avatar
yep it creaked alright at slow turns. i found out when i uninstalled them that the aluminum washer i used crushed so much that it went into the threads ruining some of the bolts! this gave me a false torque reading! properly torqued, it should not make a peep!
Old 06-10-14, 09:27 PM
  #39
johhntran
johhntran's Avatar
i just uninstalled mine, but the noise was still there.. im pretty stumped haha
Old 06-12-14, 12:03 PM
  #40
timmy0tool
timmy0tool's Avatar
torqued to 83 ft-lbs? you might have some play left over.
Old 06-13-14, 01:03 AM
  #41
johhntran
johhntran's Avatar
yeah i torqued the stock bolt without the rca at 83
Old 06-16-14, 01:35 AM
  #42
samsung201
samsung201's Avatar
Hey and sorry for my late reply im sittin in a hospital right now.
No i dont hear anything like your noise. Mine comes from the tires. I torqued like timmy0tools and works wonderful for now. I use to screw glue.
Can be to that i use three different bolt lenght for fixing the rca's.
Timmy why you yuse aluminum washers? I buyed some steel washers and cut them that sits perfectly in the hole.
I recommend to to using washers! I installed before the bolts without and saw that the hole inside beginn to become pressed!
Old 06-16-14, 11:25 AM
  #43
timmy0tool
timmy0tool's Avatar
is the noise still happening? i did notice that it does creak initially then does settle and goes away after driving a few miles.
as for the aluminum washer, it was proved in the hardware kit from studio. after removing and re-torquing a few times the washer just crushed! it was a one-time-use washer. i have stainless steel replacements.
Old 06-24-14, 10:44 PM
  #44
samsung201
samsung201's Avatar
Realy? In my set wasnt any washers. By the way i orderd yesterday some RCAs fom T-Demand!
Have enought from those Studios...
Old 07-19-14, 03:13 PM
  #45
TMAdash1
TMAdash1's Avatar
I just got my T-demands in and had a couple questions for ya:
Did you torque to 95 ft-lbs?
Were the bolts that came work or did you have to use the shorter ones like the Studio RCA
Did you have to grind the balljoint like the instructions say?
Quick Reply: studio camber roll center adjusters (RCA)
