Misfiring
Old 07-29-13, 10:59 PM
gphilemon
gphilemon's Avatar
Angry Misfiring
1996 LS 400 misfires and smoke a little on acceleration, codes are 300,302, 308, compression test are good, right coil, plugs , wires , cap and rotor, EGR replaced, temp sending unit check out good, vacuum checks out great, all injectors work, fuel pressure is also good , but codes continue the same, any help out there?
Old 07-30-13, 12:27 AM
LScowboyLS
LScowboyLS's Avatar
I would clear the codes and see if the exact same codes come back or if the 30x numbers are different (such as getting a 301 or a 305 etc.)
some possibilities:
● jumped time by one tooth on only one cam
● defective cam position sensor
● defective crank position sensor
● MAF
● ignition system issue (igniter, coil, etc.)
failing ECU capacitors
please do the tests in the service manual
Old 07-31-13, 01:08 PM
gphilemon
gphilemon's Avatar
codes are clear but same one came back, pull the ECU out and one capacitor has leakage
Old 07-31-13, 03:54 PM
LScowboyLS
LScowboyLS's Avatar
yay! - we have a winner!
Greygooser
RX - 1st Gen (1999-2003)
07-07-22 04:37 PM
4xfletch
08-20-15 02:33 PM
leya
Maintenance
01-03-14 10:17 PM
mdbrown
18
12-14-13 04:55 PM
kyote
01-26-10 10:39 AM
Quick Reply: Misfiring
