Emergency brake light always on
Old 07-29-13, 03:55 PM
CitySlaka
CitySlaka's Avatar
Default Emergency brake light always on
hello everyone i have an issue with my 1992 Ls 400, the emergency brake light is always on now even though my E-brake is off. this started a week ago and first it came on when i hit the accelerator and then off again when i tapped the brake pedal, then the next day it just stay on all the time. there is now problem while driving but its annoying. I'm sure its an electrical issue like i have had before with the trunk like so many other owners of 400+ thousand miles LS's. Any help is appreciated.
Old 07-29-13, 04:27 PM
midwest2
midwest2's Avatar
It likely means your brake fluid is low because of worn brake pads either front rear or both. Worn pads = excessive caliper travel which requires lots of fluid. Once that happens the sensor in the reservoir trips the light.
Old 07-29-13, 05:00 PM
Kansas
Kansas's Avatar
Yes, it is likely low brake fluid or at worst a failed sensor in the brake fluid reservoir but also check to see that your e-brake pedal has returned all the way upward after it has been released. The mechanism above the e-brake pedal can get pretty gunked up and requires regular cleaning. I use a rag and silicon spray to clean mine.
Old 07-29-13, 05:38 PM
CitySlaka
CitySlaka's Avatar
thnx i will try these and see if it helps . i will post back soon
Old 08-27-13, 09:10 PM
gd3tyrone
gd3tyrone's Avatar
had the same issues. gonna try that
Old 08-28-13, 12:00 AM
silos5
silos5's Avatar
had similar issue, light went on when I hit the brake pedal and stayed on. Reason: broken lamp in the brake lights.
JOHNBRAY11
RX - 1st Gen (1999-2003)
03-10-12 04:22 AM
flossabe
09-25-11 02:47 PM
AlexusAnja
11-30-10 08:19 AM
umcne100
12-27-09 04:01 PM
ChrisSC300
SC- 1st Gen (1992-2000)
11-03-02 09:52 PM
Quick Reply: Emergency brake light always on
