Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
Size matters! - let's put a BIG oil filter on our LS!
Thread Tools Search this Thread Display Modes
Old 01-31-14, 07:59 PM   #151
Yamae
Trader Score: (0)
The attached 32 pages of a PDF file shows how Denso has struggled to cope with Toyota's requirement and filters have been changed the design and the manufacturing method. It is all written in Japanese but photos and drawings may help you to know the contents some.
It explains why and how Denso needed to make current type of filters. It is the result of the cost reduction keeping performances good.
Another interesting point is that Toyota once had used Purolator oil filters in North American factories because of the cost and the quality. Later on Denso and Purolator made a company named PURODENSO in 1989 and it had been supplying oil filters to those factories. Initially the investment ratio was 50%-50% each but in 2001, Denso took over it and it's a 100% Denso company after that.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Yamae is online now   Reply With Quote
Old 01-31-14, 08:53 PM   #152
RA40
Trader Score: (6)
RA40's Avatar
Thanks! The wife can read this to me. I'f I'm not back, then...
__________________
Mike
RA40 is offline   Reply With Quote
Old 02-01-14, 07:29 AM   #153
python
Trader Score: (4)
python's Avatar
wow...get a wix/napa gold and be done with it, u guys are putting way too much effort into this thread. the only time a better filter comes into play is if u run EOC intervals of 5000+ miles..then a platinum filter should be used.
u change ur oil at 3000 miles? any filter will work for u..even a low grade fram with their cheaply made by pass and drain back valves
https://parts.olathetoyota.com/tacom...omparison.html
python is offline   Reply With Quote
Old 02-01-14, 11:17 AM   #154
LScowboyLS
Trader Score: (0)
LScowboyLS's Avatar
@vatoloco
Send a message via Yahoo to LScowboyLS
the filter comparison at Olathe Toyota (they paid Jason at TacomaHQ.com to do it, actually) is not a bad little filter comparison, but it is by no means scientific, but more observational, which can be helpful in its own right, to spot major sloppiness, but nothing that some of us haven't done at home with our filter cutters.
PS - one of the brands here, the Chinese Microgard, I would NOT use in an LS400, nor would I use an A/C Delco as I have caught manufacturing issues of great concern inside these two brands in the past.
Curious to why when someone tests a FRAM against something expensive like a K&N, they use one of FRAM'S cheapest designs, rather than their premium FRAM Ultra filter, that is still lower cost than a Bosch or K&N
The WIX, Bosch, and K&N are the best filters in this comparison, versus the lower end filters they tested against.
LScowboyLS is offline   Reply With Quote
Old 02-03-14, 09:29 AM   #155
peterls
Trader Score: (0)
Quote:
Originally Posted by Yamae View Post
Look at this. The Denso filter 90915-20004 has two different pieces of metals at bottom side of it. The one you show us is totally different from that. The additional thin metal piece is aiming to hold the gasket well.
Well I thought that Denso on rockauto sounded too good to be true. Thanks for the explanation!
Right now I am using Motorcraft FL400S, costs only $3.69 on Amazon + free shipping if you are a Prime member. It seems to work just fine, and I change my oil every 5k miles, so I hope I am OK there.
peterls is offline   Reply With Quote
Old 02-03-14, 12:17 PM   #156
LScowboyLS
Trader Score: (0)
LScowboyLS's Avatar
@vatoloco
that's a great filter, may or may not be the best LS400 filter made, but definitely the best value for one of the top 5
Old 04-10-14, 06:26 AM   #157
MattLS400
Trader Score: (0)
Thinking of putting the K&N PS-1002 Engine Oil Filter on my Celsior
Here are specs;
K&N FILTER
Manufacturer Part Number:
PS-1002
PSI Relief Valve:
11-14
SKU: KN:PS-1002
Bypass Valve: Yes
Style: Canister
UPC: 00024844287304
Filter Material: High Flow Premium Media
Thread Specification: 3/4 In. - 16
Gasket Material: Nitrile Rubber
Height: 3.75 in (95 mm)
Anti Drain Back Valve: Yes
Product Style: Oil Filters
What you guys thiNK ?
MattLS400 is offline   Reply With Quote
Old 04-10-14, 06:43 AM   #158
python
Trader Score: (4)
python's Avatar
bypass valve setting on our filters is 8-11...napa's 1348 is what is supposed to go on the car. if u want or absolutely feel the need for a larger filter a napa 1516 is the one that will work
Old 07-08-14, 04:49 PM   #159
Bill Dowd
Trader Score: (0)
I have been using the Amsoil EAO34 type for 15 years on my 1991 LS 400 with 313,000 miles and changing the engine oil at 15,000 to 20,000 miles and no problems using mobile one extended I use Mobile one in everything so far so good I also use the Mobile one trans fluid in PS trans and change it every 30,000 use 75-90 in rear end change it 50,000 I also put on a motor home trans cooler and small power steering cooler seems to help here hot So Cal.
Bill Dowd is offline   Reply With Quote
Old 07-13-14, 06:43 PM   #160
ceedub53
Trader Score: (0)
ceedub53's Avatar
I changed the oil this weekend on my 02 LS430. I went with the oversize Fram Ultra (XG3600). It is about an inch longer than the stock Toyota 90915-YZZD3 that it replaced, same diameter. Cost was $8.50 from Amazon. It's an extended change filter (15k), but I'll probably change the oil and filter again at 7500-8500 mi.
ceedub53 is offline   Reply With Quote
Old 07-14-14, 07:38 AM   #161
python
Trader Score: (4)
python's Avatar
u should do ok with the extended guard..the extra guard filters are cheaply made
Old 07-16-14, 08:38 AM   #162
blumonster
Trader Score: (0)
blumonster's Avatar
You have a Lexus LS 400 and you put Fram on it. What a shame.
blumonster is offline   Reply With Quote
Old 07-16-14, 08:18 PM   #163
python
Trader Score: (4)
python's Avatar
I agree but the higher end fram filters are pretty well made
Old 07-19-14, 06:22 AM   #164
BobN54
Trader Score: (0)
I prefer the Purolator PureOne 20195. I stocked up a few years ago, and soon will need to restock. Not sure where to get them at the right price nowadays.
BobN54 is offline   Reply With Quote
Old 07-20-14, 03:45 PM   #165
peterls
Trader Score: (0)
I just bought a box of Toyota filters for $40. With such low prices, it is hard to justify using anything else, unless there are better filters our there...
Tags
10w20, bosch, filter, good, gx460, kn, large, lexus, ls, ls400, mobil, mobile, oil, oilfilterls430oversized, wix, xp
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Advertising
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
Content Relevant URLs by vBSEO 3.5.2
