OEM Navigation Swap for OEM Pioneer Stereo
Old 05-09-13, 07:32 PM
Tinggi
Tinggi's Avatar
Default OEM Navigation Swap for OEM Pioneer Stereo
I have found a number of threads discussing the install of a aftermarket unit and a number explaining the cost and time required to change a NAK head to Pioneer and vice versa but have not been able to find any one who has changed the Pioneer Navigation head and climate control for the Pioneer Stereo head and climate control!
Can this be done with out too much modification of existing harnesses/brackets?
My NAV is working fine but the GPS only works in the US (the way the program was developed). I like stock and would seriously consider changing out to the Pioneer stereo and climate control if it was not too much trouble.
I appreciate any help in this matter.
Regards,
David
Old 05-09-13, 10:50 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
just need the factory '98-00 pioneer headunit and climate control, will plug right in. Don't believe you need any other brackets and you SHOULD be able to use the ones on the navi.
Old 05-10-13, 04:56 AM
Tinggi
Tinggi's Avatar
I thought that was the case. Thanks for the response.
Will be looking for Pioneer head unit and climate control.
Regards,
Old 05-12-13, 08:47 PM
Tinggi
Tinggi's Avatar
Default Switch OEM Nav with OEM Stereo
Pure Drifter
That the brackets are interchangeable is excellent. Will the Nav harness plug in to the stereo head and function correctly?
Thanks
Old 05-12-13, 10:55 PM
PureDrifter
BahHumBug
for pioneer, yes.
7akata
SC- 1st Gen (1992-2000)
13
08-30-14 10:40 PM
BlaineyB
02-01-11 12:12 AM
big basset
02-10-10 07:00 PM
flamekat
08-07-06 06:28 PM
Quick Reply: OEM Navigation Swap for OEM Pioneer Stereo
