Ac question??
Old 04-25-13, 01:20 PM
LS400BOY
LS400BOY's Avatar
Default Ac question??
on my 92 ls, i had got my ac charged works great but have been noticing that the ac button flashes when i come to a stop,like the ac stops blowing cold
Old 04-25-13, 07:36 PM
ttyR2
ttyR2's Avatar
I would bet the compressor isn't spinning, or spinning fast enough. When the compressor on my 1990 died, the same thing happened because the tach sensor for the compressor sensed it wasn't spinning.
If there is a compressor pressure sensor, it's possible it's reading a pressure problem.
Old 04-26-13, 04:46 AM
LS400BOY
LS400BOY's Avatar
But only does it when i stop,when im driving its fine
Old 04-29-13, 11:39 AM
LScowboyLS
LScowboyLS's Avatar
sounds like your compressor clutch coil - what is the gap on it?
Old 04-29-13, 11:41 AM
LS400BOY
LS400BOY's Avatar
How do i go about finding and doing this?
Old 04-29-13, 01:30 PM
rick1987
rick1987's Avatar
When you stop the engine is at idle, and the motor probably is not spinning the compressor fast enough.
Old 04-29-13, 04:46 PM
LScowboyLS
LScowboyLS's Avatar
I would use a feeler gauge, like you would use to check spark plugs or valve lash
Silgs300
06-25-18 06:50 PM
pdavid2204
LX - 3rd Gen (2008-2021)
12-06-17 09:29 AM
hazepurple
11-27-11 07:48 PM
SC400Chinx
SC- 1st Gen (1992-2000)
08-17-05 08:55 PM
Quick Reply: Ac question??
