heater/ac fans not blowing.....???
Old 04-04-13, 08:11 PM
bwils
bwils's Avatar
Default heater/ac fans not blowing.....???
the buttons and all work fine.. i'll hit the mode button or whatever and nothing happends? anyone know why no air is blowing
Old 04-04-13, 10:02 PM
LScowboyLS
LScowboyLS's Avatar
no air blowing can be the following:
1. blower fuse and/or relay
2. blower motor (give it a sharp whack and if it comes to life, it's bad)
3. ECU issue
4. blower resistor
5. the control panel and/or its circuit board
get a 2 day membership to to the factory's Toyota Information System for $15, and download the appropriate factory service manual section for your model year and go through the troubleshooting steps.
Old 04-05-13, 06:32 AM
bwils
bwils's Avatar
alright thanks man.
Old 09-24-14, 05:28 PM
edd6499
edd6499's Avatar
Default Blower Motor / A/C Clutch
1998 LS400 - My A/C clutch is failing, but up until today the A/C had been working, just making bearing noise. Today I had the blower motor on just blowing air (not A/C at the time). Hit the A/C button and the blower motor completely quit. Found that the fuse under the dash had blown and replaced it, still no blower. I know there is a relay and I think it is a small black cube in the fuse panel under the hood (marked heater on the panel diagram?). Has anyone heard of a failing A/C clutch taking out the blower motor when the A/C is switched on? What else should I be looking for to just get the blower motor working again? Thx
Elias470
GX - 1st Gen (2004-2009)
06-06-19 04:56 AM
tyncobb
02-12-19 04:37 PM
davidyal
RX - 1st Gen (1999-2003)
07-26-17 09:16 PM
CarQueen
07-08-15 02:26 PM
2ndgen400
07-05-14 03:50 PM
Quick Reply: heater/ac fans not blowing.....???
