Need help!!! Doesn't start after throttle body cleaning
Old 03-22-13, 06:34 PM
lhgdale
lhgdale's Avatar
Default Need help!!! Doesn't start after throttle body cleaning
Hello, I just cleaned my throttle body per the instructions on lexls.com. I just put everything back together and now when I try and crank the car it just makes a thud like the battery is dead or doesn't have enough power to turn the motor over. I used valvoline throttle body cleaner and cleaned out inside the throttle body and intake really good. I used about 2 cans of it. The battery has never been an issue and was just trickle charged. The battery was disconnected the entire time I was working on the car. Thanks for any help and suggestions!!!!
Sorry, 92 LS400 113500 miles.
Old 03-22-13, 08:49 PM
sha4000
sha4000's Avatar
Well get someone to give you a boost just to rule out the battery for starters.
Old 03-23-13, 07:14 AM
lhgdale
lhgdale's Avatar
Got it running this morning. It took a few extra seconds to crank. I guess due to all the throttle body cleaner.
Posted from ClubLexus.com App for Android
Old 03-23-13, 08:41 AM
fixmiester
fixmiester's Avatar
Default May have dodged a bullet
I hope you didn't use two cans of cleaner with the manifold in place! If you did, it's almost certain that it ran down inside one or more cylinders. You would have created hydro-lock, and even busted a cylinder head if your starter had more power, or had fired up right away. If you are trying to clean the manifold in-place, it is absolutely necessary to pull the plugs and crank the starter several seconds to blow that stuff out before putting the plugs back in..
Old 03-23-13, 08:48 AM
johnnyg66
johnnyg66's Avatar
I would go with that when I did mine I sprayed just alittle too much. But it started ran bit rough for a few. Leasoned learned.
Hope yours recovers.
Old 03-23-13, 05:20 PM
lhgdale
lhgdale's Avatar
That sounds like what happened. I removed the piece (not sure what it's called) per lexls instructions. I would say I cleaned inside the manifold with almost a can of the throttle body cleaner. I did wipe it out with rags after heavy spraying and alot ran back out onto rags I placed on top of the motor. I did try and crank it right after getting everything re assembled and that's when it made the clunk sound. I let it sit for about an hour and it turned over like normal. Took a few seconds to fire up. Drove the car today and it seems to run fine.
Old 03-23-13, 06:41 PM
cobalt91
cobalt91's Avatar
Good job cleaning up the intake. Looks good!
Old 03-23-13, 08:23 PM
lhgdale
lhgdale's Avatar
Thanks, I used a flat head screwdriver. It was like taking a few layers of paint off a wall, that stuff was thick.
nobelnabil
09-09-18 03:22 PM
ShunDoe
06-08-16 12:37 PM
shikbas
06-22-11 02:39 PM
bighead222
SC- 1st Gen (1992-2000)
05-16-11 05:17 PM
bighead222
05-16-11 03:02 PM
Quick Reply: Need help!!! Doesn't start after throttle body cleaning
