92 LS Distributor Cap/Rotor Change and Clean TB???
Old 03-21-13, 04:42 AM
lhgdale
lhgdale's Avatar
Default 92 LS Distributor Cap/Rotor Change and Clean TB???
Hello, the last 3 things I would like to clean and change on my 92 LS with 113,000 is the distributor cap, rotor and clean the throttle body. I have read the write ups on lexls.com and google searched for info. The throttle body cleaning seems simple but all the info I find on the distributor cap and rotor seem like you have to remove alot of stuff. I just changed out my power steering pump and replaced the plugs and plug wires so I have had the engine disassembled a good bit. Just looking for any tips or easier ways to clean and change out these items.
Thanks very much!
Old 03-21-13, 05:54 AM
johnnyg66
johnnyg66's Avatar
Rotors and caps should have been done when you did plugs and wires. Since you had it apart than now you have to do it again.
Cleaning the throttle body the way without removing it only gets it halfway clean. Its ok but add some good cleaner to fuel tank or try a BG system cleaner service at a auto shop.
Old 03-21-13, 12:53 PM
lhgdale
lhgdale's Avatar
Yeah I know. I didn't have the $ at the time so I'll be doing some extra work. I will be removing the throttle body to clean it.
Posted from ClubLexus.com App for Android
Old 03-23-13, 07:23 AM
lhgdale
lhgdale's Avatar
Here is a few pics.
Old 03-24-13, 03:41 PM
lhgdale
lhgdale's Avatar
Ordered a set of Bosch distributor caps and rotors today also got a new thermostat. I might as well change that too while I'm right there.
Old 03-25-13, 11:26 PM
sam12345
sam12345's Avatar
Report if the distributor and wires did anything. I am still on the original ones and I am convinced they are good , I got 165k and 21 years on them. Reason I say so is because my acceleration is to spec. Anyone else use acceleration, 0 to 60 to determine if the car is running as it should? (as well as mpg)
Don't forget your coolant temp sensor while you are at it. 14 bucks at autozone
Old 03-26-13, 03:59 AM
lhgdale
lhgdale's Avatar
Will do, my plugs and wires were the originals and they were in pretty bad shape so I'm guessing the distributor and rotors may be the same. It will give me piece of mind anyway.
Old 03-26-13, 10:13 PM
LScowboyLS
LScowboyLS's Avatar
Dude, keep your Lexus running like a Lexus! - Always use genuine OEM NipponDenso ignition and fuel injection parts!
Old 03-27-13, 04:49 AM
lhgdale
lhgdale's Avatar
Now you tell me! The Bosch meet or exceed the manufacturers specs. At least that's what they say.
Old 03-27-13, 07:26 PM
305ls400
305ls400's Avatar
my ignition coil, distributer cap and rotors had 225.00 original miles in them i just change them today. all bosch it runs good i notice i big difference i also change o2 sensor, i had change the wires and spark plugs 9 months ago.
Old 03-27-13, 08:23 PM
lhgdale
lhgdale's Avatar
Good to hear, I'm doing the install tomorrow. I also picked up a coolant temp sensor like suggested.
Old 03-27-13, 08:38 PM
LScowboyLS
LScowboyLS's Avatar
please see my OEM thread to find out who is the real OEM maker of different parts on your car, then shop the real thing online!
Lukas99GS
06-16-17 01:36 AM
lexus-is2
12-15-13 09:32 AM
4kzmooch
04-08-13 05:16 AM
matrixgts
Performance & Maintenance
11-09-08 05:20 AM
twodmax
10-30-06 07:03 PM
Quick Reply: 92 LS Distributor Cap/Rotor Change and Clean TB???
