Megan Coilovers on a UCF10
Old 03-20-13, 11:03 AM
timmy0tool
timmy0tool's Avatar
Originally Posted by lsd4hunnit
Should've gone Function&Form Type 2s! I'm on the highest setting, and cant go any higher and it sits really low!
if you read his post he wanted coils but to be at the stock height. type-2s are new to the market and are typically for folks who want to slam their cars, something the OP didn't want.
but i understand your confusion, since most folks going coilovers always has the intention of lowering the car.
Old 03-20-13, 04:23 PM
cheesey1x
cheesey1x's Avatar
Thanks No hella flush for me right now...
I took some measurements on my car today:
Front
235-40-18
3" fender space from top of tire to bottom of the fender lip at 12:00 position.
25" from groun to bottom of the fender lip at 12:00 position.
Rear
255-35-18
3.5" fender space from top of tire to bottom of bender lip at 12:00 position.
26" from ground to bottom of fender lip at 12:00 position.
Front lip 9" clearance from ground.
Now I'm thinking a 2 inch drop is going to be too much for me..
I know it sounds stupid but can anyone tell me the height of the Megan struts when the length is maxed out?
Is it the strut length plus the spring length? so
220mm (spring)
200mm (strut)
= a max length of 420mm or 16.53"?
stroke length 115mm or 4.72"
The KYB page lists the stock fronts with this data:
extended length 20.71" or 526.34mm
compressed length 15.59" or 395.86
stroke 5.12"
If the math is right then it puts the front height using KYB LP's at max length at stock max compressed height using stockies?
Does not compute.....
Help please thanks!
Old 03-20-13, 07:38 PM
DannySz
DannySz's Avatar
i dont understand why to buy coilovers to keep a 3" wheel gap.. Or any wheel gap at all
Old 03-20-13, 07:47 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
Front
235-40-18
Rear
255-35-18
220mm (spring)
200mm (strut)
stroke 5.12"
Help please thanks!
you're not measuring from stock height, you're measuring from your worn out suspension's ride height.
Old 03-20-13, 08:44 PM
radiokilla
radiokilla's Avatar
I have Megan LP's on my UCF10. To get it to the desired ride height I wanted (wheel lip to fender basically) I had to take out all the rear preload. I would go with BC's.
Old 03-20-13, 09:50 PM
PureDrifter
BahHumBug
OP wants higher, not lower.
Old 04-28-13, 05:00 PM
Dubbayoo
Dubbayoo's Avatar
Wait....conflict.
Purediftner said:
the megans can't get close to stock height or ride, minimum 1.5-2" drop in the front at max height.
but xtremex626 said:
if you're not looking to drop the car real low, then the megan ez's are your best bet.
I don't want super low but Atlanta roads are fairly good except one street on the way to work.
Old 04-28-13, 05:26 PM
PureDrifter
BahHumBug
no conflict.
the megans simply can't get the rears as low as say the BC Racing Extreme drop. But they do get low enough for ~80-85% of people.
Old 04-28-13, 09:08 PM
Hodson
Hodson's Avatar
I know pure Drifter added his input but anyone else running EZ's/...... How far was your drop from stock with these?
This is my UCF10 on megan EZ streets. The 95-00 application bolts directly in, they fit perfectly. Don't listen to the dummy you were emailing at megan.
My rears in the picture are at maximum low, they can raise probably 2-3 inches higher still. The fronts can raise another 1.5 or 2 inches I believe as well. The ride is still pretty comfy, definitely sportier than stock though.
Old 04-29-13, 03:30 AM
j2b4o
j2b4o's Avatar
The problem with the Megan's is that the rears will get you where you want to be but the fronts will max out real quick. The fronts go lower than the fenders will allow but the rears only give maybe 2-2.5" drop max. Poor design, I am also seeing clear difference in dampening strength between the corners. In other words they are also poorly pared so with the right set at 8 and the left at 8 one side is clearly stiffer.
Old 04-30-13, 03:52 PM
dustinls4
dustinls4's Avatar
This thread is a big help even for me! I also was wondering the same thing about the megans. Im glad I wasnt the only ones. But after doing some looking around I think bc is a good choice. Not trying to thread jack
Old 05-01-13, 11:19 AM
SuicidnS13
SuicidnS13's Avatar
Eeek. 1.5" - 2" drop may be a bit much for my daily drive. The damn AF Bases like to put up speed tables so a hella flush drop is out of the question. I already scrape sometimes even going over diagonally.
I'm not running anything crazy
IS350 stock 18" rims
235 40 18 in front
255 35 18 in rear
I was hoping for a coilover replacement esp since KYB blues and H&R springs will cost just as much as a coilover set...
Any other suggestions?
LOL - dont be scared of them... my boy works on base with you and drove these in like this on the daily
http://www.flickr.com/photos/suicidns13/8371243903/http://www.flickr.com/photos/suicidns13/8371243903/ by http://www.flickr.com/people/suicidns13/, on Flickr
http://www.flickr.com/photos/suicidns13/7292581170/http://www.flickr.com/photos/suicidns13/7292581170/ by http://www.flickr.com/people/suicidns13/, on Flickr
And he made it in with no issues other than exhaust scrape.
alvinucf20
12-07-17 11:26 PM
spacecoupe
Suspension and Brakes
10-11-13 06:32 PM
MKIVS374
24
02-08-12 02:56 PM
lilkoreaGS
29
02-23-11 03:41 AM
Quick Reply: Megan Coilovers on a UCF10
