Coolant Leak? What is this tube?
Wanted to post a final follow up after I continued to have a small leak.
Listen to LSCowboy and Timmy about needing to replace the o-ring!!! This was the source of the continual, small and slow coolant leak. The o-ring is a $3 part from the Toyota dealer and something that you should change if you are working with the coolant drain ****.
Thanks again for all of the help!
TyneeGX
GX - 1st Gen (2004-2009)
15
03-25-22 07:01 PM
Johnhav430
10-26-17 11:58 AM
