Benefit to Air Box Mod???
Old 03-20-13, 01:28 AM
VanCityLS4
VanCityLS4's Avatar
Some would argue that...
What was K&N smoking when they finally put them side by side. It should have went back to the drawing board. They should do a redesign with an element in the center. There must be some documentation proving better air flow with what's pictured above. I bought it because its 'supposed' to be better. It certainly doesn't add much 'noise', I found it noticeble only above 4500 rpm.
On the topic of intakes... I know the 98-00 air inlet tube has a built in resonance chamber. It's noticible on the underside. If this is blocked/closed off, I assume induction sound should be louder ?
Old 03-20-13, 03:05 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
the resonator isn't purely for sound, it offers a certain performance advantage as well.
In terms of sound though, it doesn't quiet the intake so much as it reduces drone at select rpm.
Old 05-26-13, 11:41 PM
VanCityLS4
VanCityLS4's Avatar
So a while back I did my version of the 2 known intake mods. The filter pod has a half cut on the bottom edge. I removed the resonance chamber as discussed above & Gorilla taped the holes. Completed a custom fit heat shield sealing off the air box compartment. It fits pretty snug & protected any edge that came in close contact to components around it. I also removed most of the headlight gasket for fresh air. Now it sounds much better & seems to rev more freely.
Old 05-27-13, 06:28 AM
Lavrishevo
Lavrishevo's Avatar
If anything, this style of the short ram air might be beneficial. Obviously, it would require some major custom work for the MAF.
Attached Thumbnails Benefit to Air Box Mod???-ram-air-300x225.jpg   Benefit to Air Box Mod???-ram.jpg
DickH
Performance
90
05-08-22 08:55 AM
IS350HKS
Performance
17
03-05-09 08:27 AM
1995LS400
03-12-08 09:31 AM
MrX
RX - 1st Gen (1999-2003)
11-19-02 12:42 PM
Quick Reply: Benefit to Air Box Mod???
