Looking into getting a high mileage LS400, Advice?
Old 02-25-13, 04:49 PM
Diesel350
Diesel350's Avatar
Spoke to the guy today and he said the car was bought from the dealer and he does not know if he is the second owner and he does not know if the 90k mile service was done so that makes be nervous.
Old 02-25-13, 07:08 PM
timmy0tool
timmy0tool's Avatar
for 90-94 cars, there really isn't anything to be nervous about since the motors are non-interference. if the belt does break, it will just cause a stall. to me it's an indicator to work the price down since it is a $1000-1500 job. i've seen belts go well into the 150k mark w/o a replacement. it's really the water pump that i feel will fail first, or contribute to the belt failing.
you can always check the history at the dealership using the VIN number, if it indeed was bought and maintained at the dealership (factory dealer, not a 3rd party used car dealer).
Old 02-26-13, 12:28 AM
LScowboyLS
LScowboyLS's Avatar
recommend a 95 or newer due to several improvements on the car, 98+ had many more improvements
the main thing is you want to see the CARFAX and you want a never wrecked car
I would never buy any car without seeing the carfax first, you would not believe what I have found on a carfax before! - it could be a Hurricane Katrina or Nashville flood car for all you know, cars get shipped all over the country! - Never buy a flood car.
a wreck in the history tends to destroy the legendary Lexus reliability, take your time and find a one-owner cream puff!
I looked at LS400's for 4 months before buying my 96
Old 02-26-13, 02:26 PM
Diesel350
Diesel350's Avatar
What about the suspension/shocks on these cars after 100k? How do they hold up?
Old 02-26-13, 05:11 PM
ISFPOWER
ISFPOWER's Avatar
would you guys stay away from a 1993 with 210k miles? how much is a timing belt job on t his vehicle?
Old 02-26-13, 09:24 PM
sam12345
sam12345's Avatar
Depends how **** you are. If you are real **** you need to change at 80k if not so particular than 150k car will feel floaty after 130k
Old 02-26-13, 09:43 PM
LScowboyLS
LScowboyLS's Avatar
how much is a timing belt job on this vehicle?
$1200+ at the dealership, but consider doing it yourself if you are pretty good with tools and attention to detail, it is really one of the easier cars to do, longitudinal engine and lots of room!
Old 02-26-13, 09:44 PM
ISFPOWER
ISFPOWER's Avatar
Originally Posted by LScowboyLS
about $1200 at the dealership, but consider doing it yourself if you pretty good with tools, it is really one of the easier cars to do, longitudinal engine and lots of room!
I did my old eclipse GST, but honestly, i dont to do things like that anymore and its well worth paying a mechanic, lol. unless it's an aftermarket part, i dont enjoy working on cars like i use to.
if the dealer charges that, im sure shops can do half the price.
Old 02-27-13, 03:40 AM
ls400geek
ls400geek's Avatar
If I could do it over I'd get a 95-97 over my 98. Sure it has 30 less horsepower, but it's a pain to replace the camshaft seals on a 98 (10 hours labor on top of the timing belt & water pump change charge). It cost me $2300 to have the timing belt, water pump, pulleys, camshaft seals & crankshaft seal done.
Camshaft seal replacement on pre-98 is pretty trivial (minutes of work).
Old 02-27-13, 05:05 AM
Aron9000
Aron9000's Avatar
Man the real thing about your shocks wearing out is how well our your local roads maintained.
I have driven our family's 2000 Avalon since I was 16 and just got my license. That car is now 13 years old and has 225k miles on it. Honestly the shocks feel a bit "worn", if you're driving a curvy road, as it leans more than it should in corners and feels a bit sloppy.
Driving it over a worn/bumpy interstate at 70mph it still feels just fine. It just kind of floats/smothers those imperfections, honestly even at this mileage its one of the best riding cars I've ever been in, and I've owned two full size RWD Cadillacs for comparison. The old Avalon tracks more precise in a straight line than those old Cadillacs as well. Its almost too precise, as I find it easier to drive straight ahead with a little bit of slosh like those old Cadillacs had in them.
BTW old Cadillacs tend to drive pretty damn straight if the alignment/ball joints, pitman arm, control arm bushings, all the front end parts are working correctly. Once they get more than 70-100k miles on them they tend to get that sort of wander about them, that sort of big car slosh in the steering if you don't do some front end work on them. Cars living in the rust belt with lots of pot-holes tend to really wear out those front end parts quick
Which is why I love the Lexus LS400, they tend to track pretty damn straight at 100k, 150k, 200k.
Old 03-23-13, 05:48 AM
Diesel350
Diesel350's Avatar
Ok I just found a 2000 with 56,000 miles on it selling for $11,800, clean title. Going to see if I can look at it this weekend.
Old 03-23-13, 06:10 AM
billydpowe
billydpowe's Avatar
I just bought a 99 with 228k for $4800. from the 2nd owner, first was a Dr. who drove between Dallas & San Antonio and ran up the miles to 168k , Sewell replaced TB/WP at 130k, second owner put 60k on it, all 4 struts & bushings, new brakes, and just wanted out before 230k job again.
Attached Thumbnails Looking into getting a high mileage LS400, Advice?-100_3594.jpg
Babygizmo
14
02-12-22 09:41 PM
Homunculus
06-17-19 05:47 AM
Patsum
09-04-11 09:44 AM
david515
01-07-11 12:21 PM
Noela
10-18-03 09:20 PM
Quick Reply: Looking into getting a high mileage LS400, Advice?
