O2 Sensors
Old 02-06-13, 06:35 AM
Queen1899
Queen1899's Avatar
Default O2 Sensors
Hi!!
I have a 1990 LS400 that needs new O2 Sensors. Does anybody know the specific sensor or name of the sensor, so that I can order the correct ones? Going to the dealership is out of the question, because it's soooooo old!!
Thanks!
Old 02-06-13, 07:03 AM
sha4000
sha4000's Avatar
Originally Posted by Queen1899
Hi!!
Thanks!
Just go here and find your vehicle and click in the emissions drop down menu.
http://www.rockauto.com/catalog/raframecatalog.php
Old 02-06-13, 08:05 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
Denso makes the OEM sensor for your car.
Old 02-12-13, 05:17 AM
Queen1899
Queen1899's Avatar
Thanks for your help...I got the transmission mount, now I have an leaky oil gasket problem. Does this car have an oil gasket or does it just need a seal? I can see smoke coming from the back of the motor where the oil leaks out. Any suggestions?
Old 02-12-13, 09:27 AM
DannySz
DannySz's Avatar
Not to thread jack, but I also need to change them together with other parts. Is there any website with a list of part numbers?
Old 02-12-13, 10:11 AM
DannySz
DannySz's Avatar
ok, found this website with part numbers and diagrams.
http://lexus.sewellparts.com/parts-c...S400-1990.html
Old 03-10-13, 05:53 AM
Queen1899
Queen1899's Avatar
Default Big Cloud of Smoke
I have a 1990 Lexus LS400. When I first crank it up a big cloud of smoke comes out the exhaust pipe. It lasts for about 5mins. Is there anything that I can buy out of the auto parts store that will temporarily stop the smoke until I can get it fixed. I was told that it was a piston ring.
Old 03-10-13, 06:30 AM
python
python's Avatar
its not piston rings!
Old 03-10-13, 06:56 AM
Queen1899
Queen1899's Avatar
Default Smoke
What could it be if it's not the piston rings and what can I do to stop the smoking?
Old 03-10-13, 08:18 AM
YoshiMan
YoshiMan's Avatar
smoking on the initial start up that quits after a few seconds is old valve seals 99% of the time on Toyota engines. They are relatively cheap parts in general, but it takes a little work to get to them.
Old 03-11-13, 02:46 PM
Gene01
Gene01's Avatar
If the smoke is white (not blue or black), it is possible that you have the classic problem with power steering fluid leaking through the vacuum system. There is a very extensive thread on this topic.
Lmood
IS F (2008-2014)
02-19-14 08:57 AM
SEANCLIME
02-15-12 06:51 PM
1stGS300
07-18-11 02:52 AM
LexXxuS101
Performance
15
01-13-11 10:38 PM
StanVanDam
06-01-10 02:13 PM
Quick Reply: O2 Sensors
