1998 LS400 -- CLICK CLICK CLICK Behind Glove Box ..
Old 02-01-13, 09:13 AM
ls400geek
ls400geek's Avatar
Default 1998 LS400 -- CLICK CLICK CLICK Behind Glove Box ..
.. usually when starting up cold. It repeats the click about 10-15 times then stops.
Anyone have any idea what this could be?
(180,000 miles)
Old 02-01-13, 11:52 AM
Legender
Legender's Avatar
I had a similar noise coming from my glove box (99 LS) ... very similar noise, didn't happen all the time... drilled it down to the in cabin filter access panel at the back of the glove box... it was in wrong and make the noise as it was loose and would sometimes bang on the glove box itself. Removing and re-installing fixed the problem... hope yours is as easy to fix... only way I found it was to let someone else drive while I disassembled the area till I got to the noise...
Old 02-01-13, 12:18 PM
door331
door331's Avatar
I was also going to suggest looking at the Cabin Air Filter area - there is a fan back there - if something is loose it could be tapping against the fan periodically.
Puttster
RX - 1st Gen (1999-2003)
07-17-17 05:26 AM
saifm73
11-30-15 07:30 PM
junes
GX - 1st Gen (2004-2009)
01-30-12 10:19 AM
pjonkheer
11-25-08 05:45 AM
Quick Reply: 1998 LS400 -- CLICK CLICK CLICK Behind Glove Box ..
