1990 ls 400 Window problem
Old 01-31-13, 02:13 PM
ls400beast
ls400beast's Avatar
Default 1990 ls 400 Window problem
Ok so im going to try and explain this as detailed as i can will post Video As soon as i get a chance. Now ive been having issues with my window it used to Go Up and down now it dosent do either. One Would say thath the Window regulator is faulty but i have disembled and it does work if i out it back to gether all it does is bend the door pannel wher itrs attached. If i push it to go up it bends in if i push it to go down bends out agian i have not seen this problem before all other windows work fine please give me some insight on what you might think it might be thanks for all your help
Old 01-31-13, 04:51 PM
LScowboyLS
LScowboyLS's Avatar
have you tested to see if the window motor has power to it when the driver's window button is pressed? - if not, you have an issue in the master driver's switch most likely, if you do have power when the button is pressed, then you have a motor or regulator problem
milirx450h
12
01-22-20 07:57 PM
beachit321
02-28-18 06:54 PM
supra9398
SC- 1st Gen (1992-2000)
05-17-14 05:48 PM
JiBBeL
RX - 1st Gen (1999-2003)
09-08-10 11:12 AM
tuninghaus
06-25-07 01:46 AM
Quick Reply: 1990 ls 400 Window problem
