What is the average cost to have Valve cover gasket fixed?
Old 01-09-13, 06:37 AM
makecopies
makecopies's Avatar
Question What is the average cost to have Valve cover gasket fixed?
What have you guys paid at either the Toyota/Lexus dealer or a independent?
Trying to find a average price
Old 01-09-13, 06:46 AM
python
python's Avatar
what year? passenger side on a gen 1 is listed in mitchell labor as about 2 or 3 hours i believe...drivers side a little less. as for replacement cost..that depends on labor rate. you will need to get the spark plug tube seals if they arent in the gasket set...call toyota not the lexus dealer because they are cheaper. if u need the part number call lexus and ask them...then call toyota and give them the number. you will need 8 total and u might as well do the cam plugs as well (located on the back of the heads)
Old 01-09-13, 06:54 AM
makecopies
makecopies's Avatar
Im pretty sure its both sides its a 95 LS. Its leaking oil pretty bad
Old 01-09-13, 06:59 AM
johnnyg66
johnnyg66's Avatar
I let my normal shop do mine awhile back both sides was around 500. Like said get cam plugs!
Can be done yourself but i didnt want the hassle.
Old 01-09-13, 08:49 AM
SpencerT
SpencerT's Avatar
Its expensive for how easy it is. its just time consuming.
get yourself 2 gaskets, 8 spark plug seals, and a tube of high oil rtv sealant.
I did mine with zero mechanical ability and had no trouble.
make a day of it and go ahead and do the plugs and wires and clean the throttle body while your there.
I believe I was quoted 5 hours of labor. or 500.
with all new parts I still saved about 300
Old 01-09-13, 10:57 AM
makecopies
makecopies's Avatar
So how close is this 90-94 VCG DIY compared to trying it on my 95 model?
http://www.lexls.com/tutorials/engine/valvecover.html
I have done a VCG before on a 3 series BMW and it was alot easier than this one looks.
Old 01-09-13, 11:38 AM
SpencerT
SpencerT's Avatar
Very close.
iirc the throttle body is the only thing that is different.
And its easier with ours imo.
I just labeled every hose and wire that I disconnected with a piece of masking tape and a number on both sides of the connection. Putting everything back where it belonged was a snap.
Start with the passenger side and the drivers side will blow you away with how easy it is.
Old 01-09-13, 12:42 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
$free.99 in labor if you're willing to put up with an afternoon of skinned knuckles and cursing...
Old 01-09-13, 12:50 PM
SpencerT
SpencerT's Avatar
Originally Posted by PureDrifter
$free if you're willing to put up with an afternoon of skinned knuckles and cursing...
+1
well worth it imo though...
Old 01-09-13, 01:26 PM
mantastic
mantastic's Avatar
Paid 120 for my mechanic to do valve covers and spark plug gaskets to be changed. Brought my own parts purchased online. Oh also had them change my fuel filter since they had my car and ive been meaning to do so.
Aron9000
Performance & Maintenance
14
11-09-16 10:22 AM
gtstcactus
04-12-15 04:46 PM
Bocatrip
03-26-14 05:13 PM
richonline
RX - 1st Gen (1999-2003)
11-11-11 07:48 AM
VJZ
04-10-08 09:04 AM
Quick Reply: What is the average cost to have Valve cover gasket fixed?
