1993 ls 400
Old 01-05-13, 10:59 AM
shovelhead
shovelhead's Avatar
Question 1993 ls 400
got this car and put a new batterey in it about 2 weeks ago got back from vacation batterey is dead any idea on electrical issues with this car
Old 01-05-13, 11:49 AM
LScowboyLS
LScowboyLS's Avatar
you left something on (like a map light), or else you have a drain somewhere
sometimes they are easy to find, and sometimes they are a tough mystery to crack, but you can always find them
a good place to start looking is any aftermarket electrical stuff on the car (alarm system, remote start, fancy aftermarket sound system, etc.)
Old 01-05-13, 12:27 PM
shovelhead
shovelhead's Avatar
thanks and will do appreciate the help
Old 01-05-13, 12:54 PM
LScowboyLS
LScowboyLS's Avatar
99.9% of the time, the drain isn't in anything that is Lexus factory virginal - these were the most reliable cars ever put on the road, and electrical problems on them are basically non-existent
so from my experience, drains seem to always come from where Beavis & Butthead decided to install a "cool security system" or "improve the amp and subs" or install HID lighting, etc.
ALSO BE AWARE:
the problem could be your alternator, leaking power steering fluid is a real problem on the LS400 and it will kill your alternator which will kill your battery.
check your PS fluid level and look for red fluid spots on the ground, and also throw a voltmeter across the battery terminals while the car is running at idle and see if you get 13.3V or more
Old 01-05-13, 02:30 PM
FrankReynoldsCPA
FrankReynoldsCPA's Avatar
Could also have a bad cable connection.
Old 01-06-13, 08:44 AM
steve2006
steve2006's Avatar
There should be a remote locking/unlocking on/off switch below the mirror position control panel, Lexus recommend switching this to off if the car is to be left some time to conserve battery power.
It means you will have to lock the car with the key and the same when you return.
340massive
03-27-18 08:22 AM
GJB
Southeast
21
10-24-10 06:47 AM
UTGS400
02-07-05 06:40 AM
gigo
01-23-05 11:53 PM
Quick Reply: 1993 ls 400
