rattle noise from behind the glove compartment
Old 12-07-02, 10:20 PM
Maeve
Maeve's Avatar
Question rattle noise from behind the glove compartment
Hi guys,
I took my car (94' LS400) to Big Bear last week. I used the AC/heater all time. The car went up and down the hill no problem.
On the way back, I started the engine and turned on the AC/heater and suddenly there was a "rattle" noise coming out from behind the glove compartmet. Plus there was a smell (kinda like a death rat or something). After 1/2 hour, they are all dissapear.
Does anybody know what had happened?
Thanks for the help,
Dom
Old 12-08-02, 12:29 AM
VVT-i
VVT-i's Avatar
I think some think get into your blower motor( fan) housing.
Old 12-08-02, 03:42 AM
dunn378
dunn378's Avatar
yeah I agree, I'm a mechanic and I see that alot.
Old 12-25-02, 01:54 AM
mcnelson
mcnelson's Avatar
Can you help me, any idea what it might be or what I should do? Approx. how much is a new blower motor if that is it? How hard to replace my self on a 94' GS300
https://www.clublexus.com/forums/sho...t=blower+motor
Old 12-25-02, 02:15 AM
dunn378
dunn378's Avatar
i'm not totally sure how hard it is to change the blower motor in a gs300 but i'm sure it's something u can do yourself. i went to your attachment and i saw the copy of the manual and it looks like it can be gotten to pretty easily. before u go and buy a new blower make sure u are getting power to the blower. unplug the connector on the blower and turn your heat on and make sure it gets power with a test light. let me know what happens.
Old 12-25-02, 02:18 AM
mcnelson
mcnelson's Avatar
So once i get it apart just turn any part of the heat on, and then put a 12v test light somewhere on the connector and see if it is getting power? If it is then the blower motor is shot correct, or could it still be something else? How can I test the motor itself? Thanks!
Old 12-25-02, 02:42 AM
dunn378
dunn378's Avatar
yeah ground the test light then make sure u have a good ground by touching the positive side of the battery with the point of the test light, it should light up. if it dosen't light you need to find a different ground. after u find the ground turn on the blower and touch one of the connector pins in the connector that you pulled of the blower, one of them should light. if it dosen't then your problem is most likely somewhere before the blower. but u should still test the blower since it's right there.
to test the blower your most likely going to need a 12v soure like a jumper pack or a battery. if you can get to the connector pins on the blower easily u wont have to remove otherwise pull it out. put the positive wire to one pin and the negative to the other and blower should run if it's working properly. hope this helps.
Old 12-25-02, 02:44 AM
mcnelson
mcnelson's Avatar
Thanks for your help! I hope I can get to it this week and test it out. I hope getting to the motor won't be too hard. Merry X-Mas!
Old 12-25-02, 03:15 AM
dunn378
dunn378's Avatar
i just thought of an easier way to test the power to the blower. just take the test light and touch one end of the light to one of the pins in the connector and touch the other end of the test light to the remaining pin in the connector and the light should come on when u turn on the blower. if u do it this way your testing power and ground to the blower at the same time. i should of thought of that before. MERRY CHRISTMAS!!
p.s. if you can't get the test light in the connector i use two paperclips and i insert those into the connector pins first then touch the paperclips with the light. hope that saves u some time.
Lobeaux
ES - 5th Gen (2007-2012)
08-31-15 06:08 AM
StiCk3
SC- 1st Gen (1992-2000)
03-28-08 07:04 PM
clickart
Hybrid Technology
12
03-10-08 05:03 PM
mr_man_b
RX - 1st Gen (1999-2003)
03-30-04 02:47 AM
DrewGS350
02-12-04 10:26 AM
Quick Reply: rattle noise from behind the glove compartment
