ls 400 air suspension woes
Old 12-14-12, 02:16 PM
moparmel
moparmel's Avatar
Default ls 400 air suspension woes
i recently bought a toyota celsior that has been monkeyed with by previous owners, i would like to air the system up and see whats good and whats not, they have rigged a manual fill port at the front and it appears to hold pressure, they have attempted to do the same at the rear but i cant get it to take air, the controller is unplugged and the valve in the trunk has had the wires cut and a couple have been marred together, i would like to get the rear suspension aired up as well, i have read on previous forums where people are changing systems to regular coil spring , i would kinda like to keep the air suspension to be able to adjust the ride hight, it has a digital aftermarket controler, i like the lowered stance, i have a set of 17 in aftermarket wheels that would look decent on the car they are a 17 x 7.5 and 50 mm offset , not sure of what tire size i will use but would like to retain a decent ride .
RamAirRckt
10-21-13 10:46 AM
OPSBD
01-09-10 09:18 AM
BNR34
13
01-28-08 01:51 PM
BNR34
01-25-08 05:31 PM
Quick Reply: ls 400 air suspension woes
