My first time owning a lexus and haven problems can u help with ideas
Old 12-06-12, 03:25 AM
lexi92
lexi92's Avatar
Lightbulb My first time owning a lexus and haven problems can u help with ideas
I bought my lexus bout six months ago from a privet school disrict all highway miles 256 plus miles all maintance was driven like new til bout two months ago when it started with always putting power steering fluid but there was no fluid on ground where i parked at or anywhere i went then it started to smoke white smoke when i started it then stopped after runnin for a min so i drove it little longer then it started to have a vibration when i give it gas with an leak coming from manifold or excaust so i parked it til i got the money to put it to the car. So i took it to the shop and was told by two different ppl at same shop one said that its the switch or somethin like that to do with power steering and thats whats causen it to smoke. so tune up was done on it still does it money lost. Then another guy said that motor is done for less i want it to be rebuilt i know as far as that goes i dont think thats the case it starts right up no problems and ideals low with a putt so if anyone has any ideas or from what i say the issuse are what i should when i take it to differnt shop so this is all issuse that i see Boggs out from dead stop, white smoke, ideals low, eats power steering fluid, excaust leak from manifold or pipes but still has hourse power after a min
Old 12-06-12, 05:42 AM
SaleenS7
SaleenS7's Avatar
This is brutal...
Old 12-06-12, 08:50 AM
denverdog
denverdog's Avatar
1. You need to learn to write in decent English.
2. Try the search function. Your questions have all been answered many times before.
Old 12-06-12, 09:05 AM
jb2wheels
jb2wheels's Avatar
ACV on PS Pump?
https://www.clublexus.com/forums/ls40...ystem-diy.html
Old 12-06-12, 09:48 AM
DonCorleone
DonCorleone's Avatar
God that was brutal to read.
jb2wheels is right, your problem is probably the ACV on the power steering pump. Remove the ACV and plug it with an oil pan drain plug from the local auto store and then cap off the vacuum lines on the engine.
https://www.clublexus.com/forums/ls4...ystem-diy.html
My first attempt was taking a piece of hose and looping it, as shown on page 4 of the thread linked above. That cracked shortly after so I just found a drain plug in the correct size from an autostore and it plugged the hole perfectly. Some people report the plug they got didn't fit correctly but I didn't have any issues on both pumps I tried it on. I can get the part number/post a picture of the packaging if you'd like.
Old 12-06-12, 12:19 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Yep, the PS fluid goes into the vacuum hoses and through the leaking ACV. The white smoke is the ps fluid burning. Does not smell too lovely I'd say...
Old 12-06-12, 01:46 PM
billydpowe
billydpowe's Avatar
just read the stickies at the front of the forum and your questions will be answered.
Old 12-06-12, 01:58 PM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus.
What you want is #2 in this thread:
https://www.clublexus.com/forums/ls4...ing-bible.html
Due to age, the pics are no longer active.
You'll probably find the car needs other maintenance fixes so don't be shy, update this thread so we can go step-by-step and get your car running well.
Drewry929
13
11-09-16 03:25 PM
divineVIP
12
09-11-13 12:19 PM
TunerLexx
SC- 1st Gen (1992-2000)
12
01-03-11 09:08 AM
Bon
01-01-11 08:39 AM
jaseinatl
Performance & Maintenance
05-07-08 09:58 PM
Quick Reply: My first time owning a lexus and haven problems can u help with ideas
