Welcome to Club Lexus, the world's largest and most active online community of Lexus owners and enthusiasts.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Club Lexus community today (click here to register)!
I've been battling an non-starting issue with my 1994 Lexus LS 400 with no success to date. I'm at the end of my rope and considering taking it in to the dealer for service (ugh!), so I'm turning to the forum for suggestions.
The issue first presented when my wife was on an errand and called to say the car wouldn't continue to run after starting it and that the check engine light was on.
I went to rescue her and was able to get the car to start, but it would only run with higher RPMs. Even then, it wouldn't consistently run no matter what I did. I managed to get the car home, which was not far, but I must have restarted it a dozen times in less than a quarter mile to get there.
The next day, it wouldn't even restart. It would catch, indicating the coils were firing, but would die immediately.
Using the tutorial from LexLS.com, I read check engine trouble code 14, which indicates a problem with the Ignition No. 1 Signal Circuit (left/driver side). According to the service manual:
"No ignition confirmation signal 1 to ECM (Engine Control Module) for 8 - 11 consecutive Ignition 1 signals."
Possible causes I checked:
Igniter No. 1 - verified good including power source
Primary and Secondary Coil No. 1 - verified good including coil wire
Crankshaft sensor - verified good
Camshaft Sensor No. 1 - verified good
Engine Control Module - verified good (rebuilt last year and sent back for warranty service when this problem presented to eliminate ECM as a suspect)
I reset the ECM (sometimes referenced as ECU) by pulling the fuse, and verified the code was cleared (check engine light flashes ~4 times per second). All that is required to trip trouble code 14 again is to turn the ignition switch to the ON position without cranking the engine.
Any suggestions are welcome.
This ad is not displayed to registered members. Register your free account today and become a member on Club Lexus!
keep in mind that a common reason for unexplained starting issues on LS400 are bad ECU capacitors, a known defect on LS400
In any event, until it is fixed, use starting fluid to start engine, because the starter is very difficult and expensive to replace on an LS400 (very high labor hours) and so in order not to ruin it, never crank the starter more than about 5 seconds in an attempt to start (it will start within 5 seconds after a 1 second shot of starting fluid into the intake) - if it won't crank within 5 seconds, you need to let it rest at least 15 minutes between tries
Thank you for the caution on the starter. I really would hate to exacerbate the issues with another and even more expensive problem.
The only code I get is 14 - no others.
I'm pretty certain the ECU is not the culprit. I had it rebuilt by ASI last fall and sent it back for a warranty service check as stated in the initial post.
Additional info:
It seems to catch when cranking (that point where you normally release the key), but will not run.
When I limped it home on day 1 it ran smoothly at higher RPMs, but died suddenly and often.
I'm pretty certain there isn't a fuel problem since when cranking I can smell gas (flooding due to no start). I would think that Is a safe assumption.
I had thoughts that maybe it jumped timing, but haven't gone there since it isn't likely.
I've also had thoughts that it may be the distributor. But since my coil test was a static test, swapping the coils will definitely precede action on the distributor since it is much simpler and might further eliminate or confirm the coil as the culprit.
Since your ECU was rebuilt last fall and you consider and believe it is not the problem since the fix was done at ASI. But judging from the symptoms and also from my experience, your ECU might have a new problem.
How was the ECU rebuilt?
Did they change all the Nichicon PF(M) capacitors?
Were low ESR capacitors used replacing all the Nichicon PF(M) capacitors?
I help shop owners to fix ECUs and sometimes I need to fix ECUs that are once fixed by a private company. Those were fixed using regular electrolytic caps that were not low ESR type by the company and failed again. Hearing from the owner of the car, I found that the car ran OK after the fix but it began to show a new problem in a year or so.
As I check those ECUs, I usually find caps that are not low ESR type or even some caps are not changed. Those caps that contain "quaternaty ammonium salt " should be all replaced as is written at the thread LScowboyLS indicates.
If your efforts so far do not fix the problem, I suggest you to see inside of the ECU and check what I wrote with question marks above.
I've been quite busy lately, so I haven't been back here to let you guys know the final fix for the LS400.
LScowboyLS,
No open/short issue was in the IGF1 and IGT1 circuit from No. 1 igniter to ECU
Yamae,
Back in November 2011, ASI repaired the ECM using low ESR capacitors for all the the original ammonium salt electrolytics.
When the ECM was returned for warranty service (November 2012), ASI fixed a problem they found in an area not related to the trouble code 14 (ignition circuit). After re-installing the ECM, I continued to have non-starting issues.
All troubleshooting led me right back to the ECM, thanks to some good input from several helpful souls on this board. The bottom line is that the ECM ignition circuit would function normally when disconnected from the load of the igniters, etc., but once it was reconnected, it could not drive the load. This condition was not detectable using the recommended diagnostics from the service manual, which test the ECM without the load of the igniter and incorrectly specified replacement of the igniter #1. Swapping the igniters proved that was an incorrect resolution. The problem was finally identified by using an oscilloscope and connecting a T-pin into the IGT1 signal at igniter #1 to identify the bad signal under load.
I returned the ECM to ASI with detailed info and they located an issue in the #1 ignition circuit, repaired it, and sent it back. They paid for shipping to and from since they had not fixed the described issue previously. I re-installed the ECM (again) and the ol' girl cranked right up.
Thanks again to you all for your valuable input, my wife is happy to have her car back up and running.
