Upper Control Arm Ball Joints
Old 11-03-12, 09:00 AM
E36M3
E36M3's Avatar
Default Upper Control Arm Ball Joints
My front end has clunking for a while. I jacked up both front wheels and checked for play and found nothing. I removed both wheels and found both upper control arm ball joints and tie rod ends feel sloppy. Can this be the culprit?
I did some searching but it's not clear what the real problem is. I don't wanna bring the car to the stealer and pay for diagnose if I can avoid it.
Old 11-03-12, 09:04 AM
johnnyg66
johnnyg66's Avatar
Most likely the uppers and lower ball joints. Did that solved my noise issue. Since yours is a 94 bet its all original down there.
Old 11-03-12, 09:36 AM
Joshcar
Joshcar's Avatar
Try doing the wiggle test, jack the car off the ground, hold the wheel at 12 and 6 o clock. Push at 12 and pull from 6. If its bad you should be able to affect the movement. Also if you take off the wheel check for any tears on the rubber of the ball joint. If it's torn it's likely it's finished.
Old 11-03-12, 11:01 AM
E36M3
E36M3's Avatar
Most likely. Hey thanks.
Hey thanks but I did all that to check for ball joint and tie rod play. There is no play for the ball joint and very, very slight play for the tie rod. My theory was the upper strut mounts or the strut rod. However, there isn't any clunking upon sudden braking to represent strut rod symptom... I'm stumped.
ahero4all
Suspension and Brakes
02-28-18 12:31 PM
frankjames
07-20-09 09:51 AM
92blacktt
05-17-09 05:32 PM
Benjamin T
12-29-07 07:20 PM
GliTCH
01-07-06 11:47 PM
Quick Reply: Upper Control Arm Ball Joints
