Misfiring problem
Old 10-19-12, 11:06 PM
davids2k
Registered User
davids2k's Avatar
Default Misfiring problem
Hello, I got a misfire from my car
the code are
P0300 Random Misfired
P0303 cylinder 3 misfired
P0305 cylinder 5 misfired
I changed the spark plugs and the spark plugs wire but it seem still misfire. I did a search but it seem every thread the thread starter seem to disappear and not post how they solve their problems -____-.....
Old 10-20-12, 03:35 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
your 1997 mazda miata doesn't have a fifth cylinder, try again.
seriously, model and year in OP please....
Old 10-20-12, 05:58 AM
LScowboyLS
LScowboyLS's Avatar
clear those codes, drive the car, rescan, post codes that recur along with year, make and model
Old 10-20-12, 10:33 AM
davids2k
Registered User
davids2k's Avatar
Oops 1996 Lexus LS400, Clear code while the car is off. turn the car on then the code comes back after 2 minute of the car is on.
Old 10-20-12, 12:27 PM
LScowboyLS
LScowboyLS's Avatar
which codes came back? - all of them?
if it keeps indicating cylinders 3 & 5 then it will fairly easy to figure out, either related to fuel or ignition or engine issue in those cylinders
most likely suspects:
distributor caps
injectors
the problem will definitely be one of the following:
Ignition System
Injector
Fuel Line Pressure
EGR
Compression
Valve clearance
Valve timing
MAF meter
Engine Coolant Temp. Sensor (ECTS)
ECU Capacitors
why not start with replacing dist. caps & rotors, ECTS, and ECU capacitors, in that order, as these are three common problem areas in a 96 LS and use genuine Toyota parts for ECTS and distributor caps & rotors
Old 10-20-12, 12:45 PM
davids2k
Registered User
davids2k's Avatar
P0300
P0301
P0303
P0304
P0305
2More codes just pops up
Old 10-20-12, 02:08 PM
davids2k
Registered User
davids2k's Avatar
no compression from cylinder 1
Old 10-20-12, 02:41 PM
LScowboyLS
LScowboyLS's Avatar
how does it run at idle? - how does it run getting on the gas?
could you post results of compression test for each cylinder please?
Old 10-20-12, 05:46 PM
davids2k
Registered User
davids2k's Avatar
when it idle it sputter like alot, engine shakes alot too
it sputter less when i step on gas. should i post a video of it? kinda hard to explain
crap i forgot to get the result but cylinder 1 has no compression and cylinder 3 has a low compression
Old 10-20-12, 09:47 PM
LScowboyLS
LScowboyLS's Avatar
if you did the compression test correctly, and you truly have no compression in cylinder 1, then you have major engine issues, i.e. a bent valve or a hole in the piston etc. - there is no low cost fix for these kind of problems, you are looking at big money, as no small problem can cause complete loss of compression in a cylinder.
how confident are you in your compression testing tools and ability?
Old 10-20-12, 10:49 PM
hotdawwg
hotdawwg's Avatar
Autozone bro.... I even think Pepboys can do a free test!
Old 10-21-12, 12:56 AM
PureDrifter
BahHumBug
Forum Moderator
did you recently have any work done on the car? when was the last time the timing belt was changed and what's your current mileage?
Old 10-21-12, 01:32 PM
davids2k
Registered User
davids2k's Avatar
bent valve? thats what scares me... but if there was a bent valve wouldnt all the other valve would be bent as well with it? maybe i should just stop driving the car far huh?
actually none of them do free test i went earlier =[
190k and timing belt was changed last week
Old 10-21-12, 02:42 PM
LScowboyLS
LScowboyLS's Avatar
you should not drive it AT ALL until you get to the bottom of this
uh-oh - did these codes and rough running pop up right after that? - an incorrectly installed timing belt can DEFINITELY bend one or more valves
if so - the person who installed the timing belt may well owe you an engine
Old 10-21-12, 03:28 PM
PureDrifter
BahHumBug
Forum Moderator
yeah since the LS is an interference motor, if the belt was installed incorrectly or slipped a tooth you can RUIN the heads and pistons.
if they were a shady shop they may have messed up then reinstalled the belt in the correct position.
Beto18
RX - 3rd Gen (2010-2015)
05-14-22 09:48 PM
RobBurgin
12-09-20 06:10 PM
05RX330AWD
07-10-17 10:19 AM
Lexuscoast
04-23-17 10:45 AM
PDXLex
08-14-14 08:19 PM
Quick Reply: Misfiring problem
