Airbag Suspension not level
Old 10-14-12, 07:16 PM
YAK00Z
YAK00Z's Avatar
Default Airbag Suspension not level
Hi. I have a 89 toyota celsior with air bag suspension, and on full drop the driverside sits a little higher up then the passenger. Ive been told the solenoids, but how do i check them or if it could be another issue like my aftermarket height controller (loose wiring?). Thanks.
Old 10-15-12, 10:58 AM
timmy0tool
Forum Moderator
timmy0tool's Avatar
well the aftermarket controller could be causing the problem but i tend to lean towards the air suspension on its way out. i'm assuming that this is the factory 23 year old suspension. at this age they typically display lots of problems in which most owners ditch them in favor of new aftermarket air suspension or coilovers. good luck!
Old 10-15-12, 02:05 PM
YAK00Z
YAK00Z's Avatar
Well I've noticed at times the suspension won't drop cause the wires are a tad loose and I have to press against it to get it to work, I was thinking due to that issue a position sensor wire or something could be the issus
CircuitMS
Club Lexus Vendor Marketplace
37
11-20-12 11:36 AM
garbage85
05-15-08 10:38 PM
2tirefire
12-02-06 06:49 AM
billy boi
07-28-05 07:33 AM
blake
SC- 1st Gen (1992-2000)
07-19-01 10:21 AM
Quick Reply: Airbag Suspension not level
