poor power window operation
Old 10-09-12, 10:39 AM
oldyngoody
oldyngoody's Avatar
Default poor power window operation
My passenger front power window is operating sluggishly. I'd like to get inside the door to check things out, but there must be a trick to taking the inside cover off of the door ??
I removed all visible bolts and can't seperate it from the door. It seems to be held at the center area. I didn't want to apply too much force until I consulted with this forum. Any help or ideas would be appreciated.
1991 Lexus LS400
Old 10-09-12, 12:12 PM
Shmee
Shmee's Avatar
There is usually 1-2 large bolts or screws holding the panel on around the inside handle to pull the door closed.
The screws are consealed by a cover that usually clips right over the handle itself and a gentle pry with a plastic trim tool is usually all that is needed to pop it off and expose the screws, usually very counter-sunk into the panel. A long #2or3 phillips is needed to remove them.
Often, there is another screw located behind a small cover and the door opener handle.
Sorry I'm not more help, I have yet to pull the doors on my 96 apart!
Good luck!
Old 10-09-12, 12:22 PM
steve2006
steve2006's Avatar
Follow the link below
http://www.lexls.com/tutorials/body/fdoorpanel.html
Some times some silicon spray in the window channels will sort the problem but avoid getting it on the glass.
PetesLS400
10-11-11 07:23 PM
SISMO817
GS - 1st Gen (1993-1997)
04-16-07 12:03 PM
jalperson
SC- 1st Gen (1992-2000)
12-06-02 03:46 PM
Quick Reply: poor power window operation
