my car run for 30 minutes stalls and wont start for 30 minutes
Old 10-08-12, 11:40 AM
cheyenne
cheyenne's Avatar
Default my car run for 30 minutes stalls and wont start for 30 minutes
i put new spark plugs fuel pump and fuel filter and still i dont know i was told shock sensor but it has none of the symptoms
Old 10-08-12, 12:59 PM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus.
Year, miles on car? Any dash lights? Plug it in and see if it reads any trouble codes.
Beyond that, this thread:
https://www.clublexus.com/forums/ls4...es-solved.html
Old 10-08-12, 01:32 PM
PerpLexusd
PerpLexusd's Avatar
mine does the same thing, i'm pretty sure it's one of the cam position sensors or knock sensor going out, if you look at them you'll probably see that the wire to one or both of them has been rubbing on the serpentine belt causing some wire to be exposed.
Old 10-09-12, 12:43 PM
steve2006
steve2006's Avatar
Also check the crank sensor as no output = no spark and they can become intermittent when warm.
twofanman
12-29-18 03:39 PM
cuutroweld
11-15-18 12:18 AM
Javier214
Performance & Maintenance
04-05-18 02:00 PM
edsautoacc
Build Threads
11-16-14 12:23 PM
Dustindude
11-03-11 01:27 PM
Quick Reply: my car run for 30 minutes stalls and wont start for 30 minutes
