LED tails compatible with 90-94?
Old 10-02-12, 05:33 PM
xXTACOXx
xXTACOXx's Avatar
Default LED tails compatible with 90-94?
I know they are compatible with the later versions of the ls400's.
Im worried more about fitment rather than wiring.
any reason these wont work on a 1990?
i understand the dash light may go off but what other problems would i be facing?
searched and searched found no answers : (
Old 10-02-12, 05:35 PM
xXTACOXx
xXTACOXx's Avatar
http://www.ebay.com/itm/1995-1997-LE...0cdd05&vxp=mtr
Old 10-02-12, 06:09 PM
shoob
shoob's Avatar
i think the corners are gonna be a fitment problem. i have a 93 and was looking at these too, i also was parked right next to a 98 earlier this evening, looking at the exact same thing your questioning. it looks like the trunk is wider, and the corners dont extend as far towards the rear wheel wells.
Old 10-02-12, 06:13 PM
mr. tetsuo
mr. tetsuo's Avatar
if you have deep pockets, then you can make anything fit
but like shoob said, the fitment will be way off on both the corners and inners.
Old 10-02-12, 06:39 PM
xXTACOXx
xXTACOXx's Avatar
lame. well thanks. its not worth it to make em fit. rather just put led bulbs in the stockers. : (
well appreciate the input?
has anyone actually tried swapping the later tails into the earlier models? Just as a for sure answer?
Old 10-02-12, 07:58 PM
85Krtagena
85Krtagena's Avatar
...you know they make these same tail lights for the 90-94 ls right? They have them on eBay.
Old 10-02-12, 08:00 PM
hotdawwg
hotdawwg's Avatar
So if I add these to my 1995, will my tailight light on the dash be lit?
Old 10-02-12, 08:02 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
95-97 and 98-00 lights will not come anywhere close to fitting into an '89-94 LS.
Hell, you can't even interchange '95-97 and '98-00 lights, they don't swap either.
Old 10-02-12, 08:34 PM
MrFuel
MrFuel's Avatar
Do what I did. Get some custom made.
Old 10-02-12, 09:49 PM
shoob
shoob's Avatar
i dont think theyre LED though......
Old 10-02-12, 10:07 PM
MrFuel
MrFuel's Avatar
There is no LED tail lights for the first gen LS400. The only company that made some was junction produce and they were 1,400 retail, and also you can't buy them and super rare. That's why I just custom made mine.
Old 10-02-12, 10:37 PM
shoob
shoob's Avatar
yeah, make your own, if your hell bent. you can pick up a bag of 100 leds and the resistors for about $5.00 on ebay. theyre super simple to do. im guessing each tail light will take about 250-sh. also a resistor doest have to go on every led, unless you want them blinding bright. you can actuall put like 20 in a line and only run a 1/4 watt 12v resistor.
Old 10-02-12, 11:12 PM
hotdawwg
hotdawwg's Avatar
Can someone answer my question lol
Old 10-02-12, 11:35 PM
shoob
shoob's Avatar
if it does.....remove the indicator bulb, lol.
Old 10-08-12, 09:34 AM
xXTACOXx
xXTACOXx's Avatar
Theres a module our chip in the trunk that controls it. Take out pin for. Search it
Quick Reply: LED tails compatible with 90-94?
