What did you do to your LS400 today?
Old 12-01-12, 02:58 PM
  #166
SpencerT
SpencerT's Avatar
Originally Posted by RA40
Last night's pick-up. Local Toyota dealer sent out $3.99/quart coupon. I couldn't get to that dealer but the other one did a price match. One of the upcoming weekends I'll do the partial drain. As well, the Toyota dealer sold the crush washers at $2.30 not the $6.95 one Lexus dealer nailed me for.
Thats a good deal on transmission fluid. I wouldve picked some up if I got that coupon
Old 12-01-12, 03:00 PM
  #167
SpencerT
SpencerT's Avatar
Today I installed some seat covers. But did it in such a way that I still had access to the seat movement controls, first aid kit, and pocket in the back of the front seats.
From this:
Using these:
To this:
It isnt this wrinkled anymore.
With access to all the oe hardware.
I am considering doing a tutorial for this because it turned out very nice and I took pictures.
Any interest? Ill get a tutorial up asap if so...
Old 12-11-12, 07:02 PM
  #168
dengman
dengman's Avatar
Holes where I drilled for the UCA covered.
Old 12-11-12, 07:13 PM
  #169
hotdawwg
hotdawwg's Avatar
From this:
Using these:
To this:
Very interested in this tutorial. I am also curious about the seat covers....
Old 12-12-12, 01:23 AM
  #170
cobalt91
cobalt91's Avatar
Good job on the seat covers. Looks good.
Old 09-08-13, 05:20 PM
  #171
xswingkidx
xswingkidx's Avatar
Default What did you do to your LS400 today?
today I got some G35 sedan 17" wheels to replace the stock wheels, which were in really bad condition.
Before:
After:
Old 09-08-13, 05:55 PM
  #172
SuicidnS13
SuicidnS13's Avatar
I just eco washed my car with Chemical Guys waterless ECO-WASH system. Best stuff ever
Old 09-08-13, 06:13 PM
  #173
johnnyg66
johnnyg66's Avatar
Replaced a leaky coolant reservoir tank and new coolant level sensor.
Old 09-08-13, 09:43 PM
  #174
Hiroshi12
Hiroshi12's Avatar
Finished OEM air sus to coil-over swap and it was like 100 in my garage. All good so far
Old 11-07-13, 05:49 AM
  #175
xswingkidx
xswingkidx's Avatar
today I bypassed my leaking heater core. I don't really need heat since I'm in Arizona. I also installed a k&n drop in filter to replace the dirty paper one. Unless I'm unaware of common engine upgrades, this will but my only "upgrade" for my engine.
Old 11-07-13, 09:41 AM
  #176
AtlasLS400
AtlasLS400's Avatar
Thumbs up
Painted my calipers with chrome decals and applied clear coat.
Attached Thumbnails What did you do to your LS400 today?-20131105_100330.jpg
Old 11-07-13, 02:40 PM
  #177
Sc0pe
Sc0pe's Avatar
You used high-temp clear coat, right? Either way, you get props for ingenuity!
Old 11-11-13, 05:25 PM
  #178
Shmee
Shmee's Avatar
Stripped out the trunk to find and fix a leak (turns out the last body shop to have the rear bumper off neglected to install the 6 screws along the trunk face and water was leaking in through the bolt holes), rubber coated/sealed everything while it was apart, installed new rear sway bar bushings and links, mounted a LED flood light under the passenger side rear bumper pointed down to the curb to light up the ground while backing up as not to murder my wheels while parallel parking at night!
Tomorrow I am going to tackle the front end (upper control arms, LBJ's, inner and outer tie rods, sway bar links and sway bar bushings) and the rear carrier bushings as well as finish wiring up the curb light to the reverse light. Also have to figure out where my PS is leaking from... YAY leaks!
Old 11-11-13, 06:15 PM
  #179
FrankReynoldsCPA
FrankReynoldsCPA's Avatar
Put it up for sale! Yay!
Sent from my Nexus 4 using IB AutoGroup
Old 02-17-14, 05:40 PM
  #180
J053Ph
J053Ph's Avatar
Took Ms.Lexy to the shop and found out that it will be needing new front calipers and lower ball joints.. Took it out from the shop and decided to do the work myself. I haven't bought the parts but I will be doing this project next weekend.
I also installed a new battery and fixed the tilt motor on the steering wheel.
Quick Reply: What did you do to your LS400 today?
