Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
Can I drain my coolant with a broken Drain Cock?
Thread Tools Search this Thread Display Modes
Old 08-26-12, 01:46 PM   #1
SpencerT
Trader Score: (0)
SpencerT's Avatar
Default Can I drain my coolant with a broken Drain ****?
95 ls400. Searches only led me to people asking for the location of the 3rd draincock.
I am trying to do a radiator flush on and I got the front and drivers side drain **** to open and drain just fine.
The passenger side bolt that opens the draincock appears to have been broken off by a previous mechanic. Is there any way to drain the remaining coolant without having to drill out that bolt?
If I start the car will it push the old coolant into the radiator so that I can drain it from the front drain **** or water outlet pipe?
I still want to do a flush but dont know if this is possible without being able to drain everything from the system.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
SpencerT is offline   Reply With Quote
Old 08-26-12, 03:18 PM   #2
RA40
Trader Score: (6)
RA40's Avatar
If the cooling system has been regularly maintained it is a minimal concern. If you've drained from the two locations, you are good. For all intents, I'd consider replacing the broken drain **** since you are in there. That way for future service this isn't an issue of getting the old coolant out.
__________________
Mike
RA40 is offline   Reply With Quote
Old 08-26-12, 04:52 PM   #3
SpencerT
Trader Score: (0)
SpencerT's Avatar
I just decided to flush with water to dilute any remaining coolant before running the radiator flush chemicals.
Im waiting on the to cool now then Ill flush with water untill it comes out like I put it in.
Is it normal for the car to drip water when the heater is on like when the ac is on?
its coming from 2 holes in the middle of the car. It looks like it is supposed to be dripping from there but my hands are so dirty I cant tell if its pure water or not.
Also there is a black pipe that runs along the back wall of the engine bay, the wall nearest the cabin, and it is completely covered in condensation. Also normal?
Old 08-26-12, 09:14 PM   #4
RA40
Trader Score: (6)
RA40's Avatar
If you have the A/C on to heat, yes, you will have the moisture coming out of the cabin interior that will drip out the drain pipes. I haven't encountered this since my burp routine is with heat on not with A/C activated.
__________________
Mike
Old 06-23-14, 08:25 PM   #5
RLind
Trader Score: (0)
Default Drain **** replacement
Sooo... I broke my brass screw, I cannot find the replacement screw/plug anywhere. Does anyone know these part numbers (97 LS400)
Thanks all,
Ryan
RLind is offline   Reply With Quote
Old 06-23-14, 08:53 PM   #6
RA40
Trader Score: (6)
RA40's Avatar
For the block: 9091009087
http://lexus.sewellparts.com/oem-cat...S400-1995.html
__________________
Mike
Old 06-23-14, 09:28 PM   #7
RLind
Trader Score: (0)
Quote:
Originally Posted by RA40 View Post
Thank you so much! I hope my local dealer has it in stock. It appears fairly common in Toyota/Lexus...
Similar Threads
Thread Thread Starter Forum Replies Last Post
Coolant drain and refill for 97-01 ontoy ES300 and ES330 46 09-27-13 10:44 AM
GS300 2006 - Coolant Flush newbeemech GS - Third Generation 11 02-24-13 08:37 PM
Cylinder head gasket leak - Draining coolant/oil from system LexSurfing LS400 4 08-01-12 08:14 PM
How many coolant drain ports on a '92 3VZ-FE? randal ES300 and ES330 2 07-26-12 07:15 AM
Front Drain Cock Leak 2eXceL LS400 6 06-21-10 12:49 AM
Tags
97, broken, cock, coolant, drain, hose, leaking, lexus, ls400, pipe, sc400
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
