1990 Lexus ls400 engine temp gauge acting weird
Old 08-20-12, 06:57 PM
Johngoped
Johngoped's Avatar
Default 1990 Lexus ls400 engine temp gauge acting weird
Hey guys do u guys know what could be causing this before I start my car I put the key in the ignion . The temp needle on the dash is already half way and when I turn it on it just stays there even tho the car is cold ? Any help would be nice
Old 08-21-12, 12:40 AM
cobalt91
cobalt91's Avatar
Need to check the sensor and wires going to it.
Old 08-22-12, 05:29 PM
Johngoped
Johngoped's Avatar
Can u correct this problem without pulling out the speedometer ?
Old 08-22-12, 05:43 PM
SkulCracka
SkulCracka's Avatar
temp sensor your looking for is left front passenger side of engine near the thermostat housing. pull the plug. then you should get no reading. change the sensor and see if it starts working right again. there cheap. easy to change.
Old 08-23-12, 03:33 PM
Johngoped
Johngoped's Avatar
Thanks for the reply do u know were u can buy the sensor?
Old 08-23-12, 05:07 PM
cobalt91
cobalt91's Avatar
Rockauto,autozone...search. Its on here.
Old 10-07-12, 07:22 PM
johnnyg66
johnnyg66's Avatar
Did that solve your issue?? Mine started that this weekend. Needle went to halfway mark and stayed there even after it was cold. It does move up a bit when driving but not much. I replaced the thermostat thought it was stuck closed because the lower rad hose was not warm but top is. After doing that the gauge did drop but not all the way down. Now its back up. I replaced the temp sensor last year.
So either its the sensor again or water pump??
It runs fine right now but i only taken it out on short hops around town.
Old 10-13-12, 02:57 PM
johnnyg66
johnnyg66's Avatar
Well I tried a different cluster no change. Changed thermostat no change. Changed temp gauge. Sensor and temp sensor for ecu. All no change needle just hangs around the middle all the time.
No running issues no codes. Could be ecu?
Old 10-13-12, 03:40 PM
hotdawwg
hotdawwg's Avatar
Yeah, the ECU might need to have the Capacitors replaced and re-soldered.
fuzzygrape
20
06-10-22 08:59 PM
nicky4318
12-16-17 06:53 PM
mgw234
Performance & Maintenance
04-24-13 09:06 PM
pero
GS - 1st Gen (1993-1997)
06-01-09 01:40 AM
matty169
10-19-06 12:54 PM
Quick Reply: 1990 Lexus ls400 engine temp gauge acting weird
