I am about to go change my rear shocks/struts.1995
Old 08-15-12, 04:54 AM
blkstealthpaid4
blkstealthpaid4's Avatar
Default I am about to go change my rear shocks/struts.1995
Is removing the rear seats the same as it is with the 1990?I changed my shocks on my 1990 7 yrs ago and I am wondering if the bolts for the seats are in the same location for both generations.I am guessing I wouldnt have to go in the trunk..
Old 08-15-12, 05:12 AM
akitomk3
akitomk3's Avatar
Nope, you don't need to go to the trunk. For my 96:
1. Pull up on the bottom seating pad.
2. Remove 3 bolts holding down the seat belts
3. Remove the seat belt guides on the top of the back seating pad.
4. Remove the head rest, pull the leather flap back and remove total of 2 bolts 1 for each head rest. 5. Pull down the center arm rest and get that 1 bolt too.
6. There should be 3 more bolts along the bottom of the back pad that also hold the pads.
After all of that is done you should be able to just lift up on the seat and take it out. So a total of 5-6 bolts that hold the back pad to the car, 3 seat belt bolts, like 5-6 screws for the seat belt guides.
Let us know how it goesm
Old 08-15-12, 06:29 AM
blkstealthpaid4
I got # 3 and 4 and 6 done.But # 1 is almost impossible.Let me go back and try yanking the bottom seat up.Too many hidden freaking bolts.My 90 was much easier.Let me try #1 again by pulling up on the bottom seating pad.
Old 08-15-12, 07:44 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
no bolts on the rear seat bottom, just big spring clips.
http://www.lexls.com/tutorials/body/rearseat.html
just follow up to step 5.
Old 08-15-12, 10:25 AM
blkstealthpaid4
What a PITA!The hardest part is finding the bolts on the seats and aligning the upper bolt on the shock to the interior hole and using a crow bar to align the hole on the bottom.I thought the front was tough but this was it.Thanks guys.I got it done.More hidden holes on this one than my 90.
Old 08-16-12, 10:59 AM
akitomk3
akitomk3's Avatar
Haha yes it seems really easy but it actually took a while for me too. But next time around it will only take you a few minutes to do everything haha
roberta
GS - 1st Gen (1993-1997)
08-10-23 02:35 AM
boris
01-06-11 02:23 PM
RedSC
09-14-09 06:54 AM
northtide
Suspension and Brakes
07-05-09 02:40 PM
Sweetser
Maintenance
07-16-06 03:17 AM
Quick Reply: I am about to go change my rear shocks/struts.1995
