Clud/thunk sound when coming to a stop on crappy roads
I noticed this on my BMW before I bought the LS but now notice it here too.
If I'm coming to a stop or slowing down on rougher roads it sounds like I'm driving over railroad tracks.
Is there anything in general to look for or is this older car syndrome?
Another possibility could be sway bar bushings.
I'd bet on the caster rod bushings, then upper control arms followed by lower control arm bushings and sway bar end links. How many miles are on your car? If you plan to keep it awile I'd hit all the areas I mentioned at the same time. If you are handy at all everythng is pretty straight forward to do, and then you just have one alignment to pay for.
Super Moderator
This is one of our long discussions on our aging cars and "clunks" "thumps" sounds:
https://www.clublexus.com/forums/ls4...er-thread.html
The caster bar bushings are commonly replaced since their longevity varies with road conditions. Additional noises come to the control arms followed by vibrations of the engine and tranny mounts. On the higher miles cars the rear carrier bushings and lower control arms. Figure on these aging cars, much of the rubber parts are deteriorating.
I think you are right. After reading that other thread lexTek, who I think is no longer on the forum, nailed the problem on the head. His terminology was to replace the front strut bar assembly. Can you buy the bushings for this part or do not need the whole assembly? Are there other names for this part?
And as someone else linked in another thread, this company sells the bushings so you don't have to buy the whole part saving you over 50%. When I called them today to get pricing they offered me an additional 10% off for first time customers. They list it as strut rod not bar on their website. Same difference.
http://www.armstrongdistributors.com/lexus.html
Super Moderator
The bushings were not available separately when I replaced mine. The whole bar assembly was installed. The offset in cost vs. time it takes to remove then press in the new bushings...IMO, I think is a wash. Took the tech about 10 minutes to do one side but I paid like $130 per bar and $55 for the install.
The following month I did the tie rod ends and lower ball joints. (There was a waste of one $75 alignment.) So anybody going in to refresh the front, I think might as well be efficient and replace other parts if they are suspect. On low mile samples probably not necessary but for those in the 200K mile range, I would consider it.
BahHumBug
died in 30k on my LS...
OEM rubber bushings cost ~$35-45/each. even with a high bushing in/out rate you end up better than buying the whole bar i you're doing the swap yourself.
This is good to know. I will go with OEM then. I'm just browsing through Sewell's parts right now and noticed this.
4813150110
FRONT COIL SPRING (RH - RIGHT / PASSENGER SIDE) , ROUGH ROAD PACKAGE - for $105
vs
4813150100
SPRING, FRONT COIL, (RH - RIGHT / PASSENGER SIDE) - for $97.03
Did not know Lexus made a different spring for rough roads. Interesting.
4813150110
vs
4813150100
Coulter
08-14-13 05:54 PM
