strong fuel smell/high vapor pressure
Old 08-07-12, 12:25 PM
matchesLS
matchesLS's Avatar
Default strong fuel smell/high vapor pressure
Latley I have been experiencing a strong smell of fuel in the garage and I noticed that the fuel tank seems to have excessive pressure within it. I unscrewed the fuel cap and an excessive amount of fuel vapor pressure was released. It took about three minutes to releive the pressure, with the cap cracked. Any ideas? I know that there should be some pressure in the system but this is excessive.
Old 08-07-12, 01:34 PM
cobalt91
cobalt91's Avatar
How is the car running? Any codes?
Old 08-07-12, 01:56 PM
matchesLS
matchesLS's Avatar
The car runs fine and there are no codes, no CEL.
Old 08-07-12, 03:22 PM
Lavrishevo
Lavrishevo's Avatar
Maybe you need a new gas cap. I believe they are supposed to vent a small amount to relieve excess pressure.
Old 08-07-12, 03:31 PM
LexGX
LexGX's Avatar
http://www.lexls.com/tutorials/maint...capgasket.html
Old 08-07-12, 07:11 PM
matchesLS
matchesLS's Avatar
On my way home I stopped and grabbed new fuel cap. The cap I had wasn't the origianl but I have no idea how old it was either. I changed the cap at the store and so far so good. I will post a follow up in a few days. Thanks for the help.
Old 08-09-12, 03:57 PM
GQ420
GQ420's Avatar
I too am getting lots of pressure from my gas cap, please give us an update. i may just have to replace it too. been having trouble with that for a while. thanks
Old 08-10-12, 08:56 AM
matchesLS
matchesLS's Avatar
So far so good. Still have pressure in the tank but it doesn't seem excessive. No fuel smell yet either.
Old 09-12-12, 08:48 AM
GQ420
GQ420's Avatar
Default Fuel cap Pressue
Well I ended up doing a tune up, with new spark plugs and wires, rotors, car is running great and NO MORE PRESSURE from gas cap. It ran alot better , good gas mileage and when i went to gas up I had totally forgot about the pressure and sure enough nothing came out. so im sure that was the problem.
Old 09-12-12, 09:06 AM
LexterLS40
LexterLS40's Avatar
whenever you smell gasoline or filling up the tank is a problem you must first check your EVAP system in this circuit you will find the charcoalcanister under the left front fender.
Your CCC = charcoalcanister is probably clocked with dirth.
You can buy them new at the dealer or clean it your self.
I made a tutorial for this problem let me find it for you.
Greetzzz Lexter
Old 09-17-12, 10:43 AM
GQ420
GQ420's Avatar
Thanks Lexter, yes please post up a link to see how this is done. After all I still may need to do this.
Old 09-25-12, 02:16 AM
LexterLS40
LexterLS40's Avatar
Thumbs up
I am terrible sorry for this late response but i found it, i wrote the tutorial in english but i am dutch.
The link is on a dutch Lexus forum :
It should be on your forum aswell but i cant find it anymore, this is the link with picas so good luck
http://www.lexusforum.nl/forum/viewt...p?f=108&t=3460
Old 09-25-12, 04:31 AM
LScowboyLS
LScowboyLS's Avatar
also, the factory gas cap is cheap enough, and important enough, I would go with the genuine cap
dataDave
03-31-18 12:30 PM
fastegg
07-27-15 05:17 AM
CitySlaka
06-22-11 08:33 PM
uhhhmenono
Performance & Maintenance
08-03-07 02:33 PM
Quick Reply: strong fuel smell/high vapor pressure
