first timer need help
Old 08-03-12, 08:54 AM
mbz560
mbz560's Avatar
Default first timer need help
gonna go look at a 1992 ls 400, 50k miles.
what should i look for/ask?
Old 08-03-12, 09:27 AM
mbz560
mbz560's Avatar
Default what problems are associated withe 1992
thinking about buying a 1992 ls 400, with 50k miles.
what problems are there with this car? is there a thread that explains?
what areas should i look for on this car.
thanks for the help
Old 08-03-12, 10:04 AM
SpencerT
SpencerT's Avatar
this has been discussed many many times.
Basically everything that needs to be looked at on any ls400
Timing belt and water pump are first on the list. At that mileage, I doubt its been done, but after 20 years you might be due.
Other than that the basic things need to be checked. Fluid levels and condition. Any signs of leaks on the underside of the car. All the electronics are in working order.
Whats the asking price?
Old 08-03-12, 10:42 AM
denverdog
denverdog's Avatar
and what proof is there of the mileage? if no maintenance records, that's a red flag on the mileage. run the vin # thrugh the lexus dealership system to get dealer printout of maintenance done there.
search for the "power steering bible" on this forum.
Old 08-03-12, 10:59 AM
RA010623
RA010623's Avatar
it's a car it has typical problem a car has. :P
basic maintenance should be check first
Old 08-03-12, 11:01 AM
akitomk3
akitomk3's Avatar
Welcome to CL!
If you're asking specifically then amongst the things the guys listed above for any used cars you're going to look at, like denverdog stated, read the power steering bible, they tend to leak on 1st gen, check the clusters to see if they're still function as it should. Check the climate control LCD. Having a low mileage ls400 doesn't the rest of the components don't age, especially if it sits most of the time and doesn't get driven at all.
Old 08-03-12, 11:42 AM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus.
Mostly it is the maintenance schedules for fluids and timing belt. Looking through the LS400 FAQ's will give you an idea of what is usually encountered with these cars as far as problems.-discussions.
https://www.clublexus.com/forums/ls4...ls400-faq.html
WRW76
11-12-13 03:38 AM
jerryparks
16
07-07-13 08:57 AM
ducman
06-15-12 12:14 PM
kino1161OLD
12
04-30-03 04:17 AM
4004me
01-10-02 05:47 AM
Quick Reply: first timer need help
