discbrakes: whats interchangeable?
07-29-12, 11:24 AM
I found 94 in jy with good brake rotors on it(very cheap). Question. Will the rotors work on my 91? All ready used the search button. Most of what was comin up was related to the supra conversion.
07-29-12, 01:22 PM
No, 93-94 has bigger rotors.
07-30-12, 09:39 PM
No. 90, 91, 92 rotors has same dia but different thickness, the newer year the thicker
07-30-12, 10:12 PM
BahHumBug
Quote:
Originally Posted by
qha_vn
incorrect.
89-92=10.8in. front, 11.4in. rear
93-94=11.6in. front, 12.0in. rear.
07-30-12, 10:30 PM
to upgrade: will the bracket for the calipers fit? Or does the whole steering knuckel need to be transfered? Is this a worth while swap? Opinions welcome.
07-30-12, 11:32 PM
BahHumBug
knuckles are retained, bracket+calipers+rotors+
however the upgrade is minimal, unlike the massive and noticeable 95+ 4 piston upgrade.
07-31-12, 08:18 PM
PureDrifter
incorrect.
what is incorrect in my post?
are you sure about the rotor diameter specifications? it means front rotors are smaller than rear.
07-31-12, 08:30 PM
BahHumBug
qha_vn
Yes, I am sure, and Yes, those are correct. The rears are solid rotors, the fronts are vented.
http://www.lexus.com/contact/pdf/1992/1992LSspecs.pdf
http://www.lexus.com/contact/pdf/1994/1994LSspecs.pdf (page 2 on both)
the '95 LS was the first one in which the rear brakes were smaller than the rears in both thickness and diameter.
07-31-12, 08:49 PM
thanks for the clarifications, but whats incorrect in my post?
07-31-12, 09:28 PM
qha_vn
Different diameter between 90-92 and 93-94 for front and rear.
07-31-12, 11:06 PM
Thanks for the info fellas. A retro fit from a wrecked 95 sounds like a better up grade.
07-31-12, 11:19 PM
TRDMan
I said: "90, 91, 92 rotors has same dia", is this wrong?
08-01-12, 12:07 AM
BahHumBug
qha_vn
my mistake, I must have read it as '90-94. since you seemed to be saying "no" to TRDman's post above yours.
08-01-12, 12:47 AM
TRDMan
PureDrifter
i answered no to his question "I found 94 in jy with good brake rotors on it(very cheap). Question. Will the rotors work on my 91?"
08-01-12, 06:43 AM
Are the 2nd gen rear calipers much bigger than the 1st gen?
Just did the rears on my 90' and they were tiny itty bitty baby calipers.
The ones on some corollas are bigger lol.
