Low idle at times
Old 07-10-12, 03:17 PM
Lavrishevo
Lavrishevo's Avatar
Default Low idle at times
This seems to happen only when I am in gear with the A/C off and not all the time. The engine does not shake or feel rough but the RPM does seem to be low. What do you think? It almost looks like it is idling at about 450 RPM's.
Old 07-10-12, 03:46 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
If it happened automatically, it could be your IAC sensor, or MAF.
If it happened slowly and surly there is crap somewhere clogging the IAC or MAF, and also the throttle body.
Old 07-10-12, 07:03 PM
SpencerT
SpencerT's Avatar
I think this is very common with our cars.
Mine idles at the exact same place and I have replaced or cleaned the iac maf and trottle body.
My best guess is that it is ecu problem from the factory. The same problem that causes the throttle shock around 45-55mph. I believe toyota issueds a service bulletin on the problem awhile back and came out with new settings for our ecu.
If everything else is good and this is your problem, you can pull your ecu, and have someone from that auction site flash it to the corrected settings for under $200. I wouldnt worry about it though...
Old 07-10-12, 09:05 PM
GS4_Fiend
GS4_Fiend's Avatar
If it's idling at "D", that looks normal. Try cleaning MAF sensor and TB.
Old 07-10-12, 10:17 PM
qha_vn
qha_vn's Avatar
mine does the same when in D stop at red light and A/C off.
shagool22
22
06-12-18 09:01 PM
Porter92
Performance & Maintenance
01-02-14 08:58 AM
ilovefood
08-31-09 06:38 AM
blackgs
Performance
13
08-29-04 06:37 AM
Quick Reply: Low idle at times
