95-00 LS Hood Supports
Old 11-13-02, 10:18 AM
Lexozz
Lexozz's Avatar
Default 95-00 LS Hood Supports
I just bought a pair of hood supports for $40 bucks ($20 each) at Autozone. They are 'Mighty Lift' model number 95029. Fits perfect, the only headache is, you have to reuse the ball joints from the old hood supports and slip them in the new ones, they don't come with any. I had to drill a hole in the old supports to get them out, not fun , but I saved a whole lot of money. There's no way in hell I was about to spend a hundred dollars just for hood supports. Guys check it out....its worth it
Old 11-14-02, 01:36 PM
rybikowsky
rybikowsky's Avatar
Thanks for the info.I recently had to pay the high price from dealer.They came with new ball joints.I tried to take the old ones off of the old struts could not do it.Carpe Diem
Old 11-14-02, 06:35 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
I have heard of these particular shocks as a good replacement for our hood supports. I am pretty sure they should also work for the first gen Lexi.
Old 11-14-02, 09:27 PM
retrodrive
retrodrive's Avatar
OK, I ve been messing with the old supports to take the balljoint out but it is not an easy thing to do. How exactly did you drill it?
Old 11-14-02, 11:00 PM
Lexozz
Lexozz's Avatar
Retrodrive, its not easy. What I did was use a small cutting pliers to make a tiny incision on top behind the ball joint, that gave the drill bit a sort of track to follow. You have to apply a lot of pressure to actually make a hole. It could be a little time consuming, but like I said before its better than paying a $100+ bucks. Once you get deep enough you should see a thin ring inside (cut it with the drill if not already done), pry it out and then the ball joint should pop right out.
Old 11-16-02, 11:17 AM
kreativ
kreativ's Avatar
I saw a tech at the dealer use a clip on one of the weak hood supports to keep the hood up. The clip looked like it was made to serve that task, but I guess any type of clip that can keep the hood strut in place will do.
That'd probably be the cheapest solution to weak hood supports if you don't have the skills or inclination to do what Lexozz was able to do.
Old 11-16-02, 07:20 PM
retrodrive
retrodrive's Avatar
Yeah, I have one of those...looks peretty ghetto though!
Old 11-17-02, 05:28 AM
kreativ
kreativ's Avatar
Where'd you pick yours up?
Old 11-17-02, 06:41 AM
retrodrive
retrodrive's Avatar
Got it long time ago at Sears. Don't remember any numbers or how they call that tool though.
Old 11-17-02, 03:00 PM
hyperopt
hyperopt's Avatar
Default Re: 95-00 LS Hood Supports
Lexozz,
I called my local Autozone for the hood struts but they needed to know the letter (eg. B,D,E) in front of the model number.
Can you find out the letter and which Autozone did you get the struts from?
Old 11-17-02, 04:12 PM
retrodrive
retrodrive's Avatar
Should be a "C". Just tell them that they are for the hood supports, they should know.
Old 11-17-02, 11:45 PM
Lexozz
Lexozz's Avatar
Default Re: Re: 95-00 LS Hood Supports
Originally posted by hyperopt
Lexozz,
The letter is C, you can go to any Autozone.
Old 11-19-02, 04:18 AM
kreativ
kreativ's Avatar
Thanks, I'll have to give Sears a call. I went to Kragens, and the guy said others had come in asking for the same thing, but they didn't have it.
Old 11-19-02, 01:00 PM
rybikowsky
rybikowsky's Avatar
J.C Whitney,had those strut clips the last time I checked.A thought,If someones struts are really shot,and you use the clip.I would not want to be the one with my head uner the hood if that clip failed.
Old 11-19-02, 01:20 PM
djr73999
djr73999's Avatar
Mine are somewhat losing the air also so
I use a trusty broom handle to keep it up(of course when I'm home only).
dj
jdanielca
03-09-19 12:35 PM
RCsGX
GX - 1st Gen (2004-2009)
11-08-13 04:53 PM
mtparker18
09-20-08 04:14 PM
Dx3
SC- 1st Gen (1992-2000)
10-04-06 10:42 AM
persian451
07-08-03 10:07 PM
Quick Reply: 95-00 LS Hood Supports
