Where to buy OEM struts for '99 LS400?
Old 07-02-12, 07:14 AM
dthouston
dthouston's Avatar
Question Where to buy OEM struts for '99 LS400?
Is there a reputable place to buy OEM struts for my '99 LS400 that's less expensive than the Lexus/Toyato dealer "list" price?
DT
Old 07-02-12, 08:27 AM
Diggzlex
Diggzlex's Avatar
Lexus parts now .com
Old 07-02-12, 09:39 AM
SpencerT
SpencerT's Avatar
LS400 oem shocks(struts) are made by kyb.
The kyb excel g shock is essentially oem and very reputable.
amazon . com has them for roughly $90 each.
Old 07-02-12, 10:37 AM
pmesfun
pmesfun's Avatar
+1 on KYB Excel-G.
Old 07-02-12, 11:42 AM
xtremex626
xtremex626's Avatar
yep. kyb is basically OEM in terms of struts.
Old 07-02-12, 01:25 PM
sdwtchlvr
sdwtchlvr's Avatar
You can get OEM struts from Sewell for approx. $180 with the forum discount. Best to go OEM on the struts if you're looking for that OEM comfort.
Old 07-02-12, 03:15 PM
KsportUSA
KsportUSA's Avatar
KYBs are the way to go, I think a lot of the newer Toyota/Lexus are using Tokico's also.
Either way both are a great option.
Old 07-02-12, 05:01 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
KYB makes the OEM shocks for toyota, and the Excel-G/GR2 are their aftermarket equivalent. Once broken in, they should in theory be every so slightly SOFTER than OEM.
Old 07-03-12, 08:18 AM
pmesfun
pmesfun's Avatar
In my experience they're actually a bit stiffer.
Old 07-03-12, 02:52 PM
PureDrifter
BahHumBug
Forum Moderator
drive them for a bit, i did say "after broken in".
it's hard to compare 20 year old blown shocks to week old brand new shocks. the only way anyone's going to be convinced that the KYB are stiffer than OEM is if you had NEW oem that you replaced with NEW kyb, or 2 cars with one running each, new.
leirazepol (01-16-24)
Old 07-04-12, 10:18 AM
pmesfun
pmesfun's Avatar
On my 99 Avalon I just replaced the front struts that were KYBs with 40K on them and they were still stiffer than the Gabriels right after installation. I believe those were defective though because in the rear I have the Excel-Gs with about 5k on them and they ride fine, just a bit firm which I like. Surprisingly the suspension on the LS is in good shape.
Old 07-07-12, 01:20 AM
nitotapia
nitotapia's Avatar
If you want KYB shocks or struts I know O'Reilly Auto Parts carries them. I know because I use to work for that company.
Old 07-07-12, 01:23 AM
nitotapia
nitotapia's Avatar
It also depends on the weather, and the way you drive how long shocks would last. The front shocks/struts are the main ones the vehicle uses for the front suspension which has the majority of the weight, and also it helps your brakes. You are using the 70% of the brake power in the front instead of the back, that is why changing your shocks is very important also getting an alignment helps out very much.
Old 07-07-12, 01:26 AM
nitotapia
nitotapia's Avatar
KYB's are very good, they are expensive but very good shocks. Just try to grab some of the shocks with LIFETIME warranty that always helps you out in the long run. Also do not forget to change out the strut mounts that also helps the lifetime of the shock itself.
Old 07-09-12, 10:23 PM
Lebowski
Lebowski's Avatar
I also believe I need to change the strut mounts on my 99 ls400. I have 101k and since I bought it 3 years ago (at 91k) it's been sounding like the shocks are a little loose in the front. The back might need replacing too.
Anyways, does anyone know if the KYB mounts on ebay are oem or not?
I'm assuming it's the strut mounts, since that seems to be the most common problem from what I gather.
I live in Brooklyn, NY if anyone knows of a good LS400 mechanic over here that would be great. The dealership is a rip off & I just don't feel like my mechanic now has the know how to diagnose minor problems like this.
Thanks in advance
Quick Reply: Where to buy OEM struts for '99 LS400?
