Where to buy OEM struts for '99 LS400?
Old 11-28-12, 10:43 AM
steedls400
steedls400's Avatar
Just had my oil changed and my mechanic informed me my front passenger strut is going out. He suggested KYB... While searching I found KYB Excel -G Struts for $87.00 a piece at racepages.
Old 11-28-12, 12:15 PM
Lavrishevo
Lavrishevo's Avatar
Stock Wise Auto has them for $72 / $78 Best I could find.
Old 11-28-12, 02:55 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
When I checked stepwise they were 72/109 respectively.
Amazon sells them for 320/set Shipped (if you have prime )
gotta love that 2day.
Old 11-28-12, 03:23 PM
Lavrishevo
Lavrishevo's Avatar
Weird, they just jacked up the rears. Maybe because I just purchased a pair. Also, no taxes. Tanabe's just arrived an hour ago.
Old 11-28-12, 04:03 PM
sam12345
sam12345's Avatar
Sewell Lexus
Old 12-27-12, 12:09 PM
steedls400
steedls400's Avatar
Just found a KYB EXCEL-G /GR2 set front & rear at Just Suspension for $325. The amazon went up to $339. After reading the cl reviews and forums it seems the KYB will offer close to original feel ��
Old 12-27-12, 04:41 PM
Kansas
Kansas's Avatar
Originally Posted by Lebowski
I also believe I need to change the strut mounts on my 99 ls400. I have 101k and since I bought it 3 years ago (at 91k) it's been sounding like the shocks are a little loose in the front. The back might need replacing too.
Your "loose-ness" could be worn front strut rod bushings. The factory installed ones usually wear out and cause noise and sloppyness at between 75,000 and 100,000 miles on the 98-00 LS400. I had the original strut rods and bushings on my 2000 LS400 replaced at about 85,000 miles when they were completely worn out and I'm surprised that the replacements still seem fine at 160,000 miles. The new rods/bushings completely tightened up the front end and stopped all vibration and wandering at highway speeds.
The shocks on my 2000 LS400 are still in great shape at 160,000 miles as were the shocks on the 90 LS400 when I sold it in 2003 at 183,500 miles. Shock aborbers on these cars can last a very long time.
Old 12-28-12, 08:40 AM
billydpowe
billydpowe's Avatar
do yourself a huge favor if you are going to replace your struts, see Kansas post and replace the SR bushings too, your front end will feel like new.
Old 12-28-12, 01:23 PM
brianmch
brianmch's Avatar
besides the struts, strut mounts, and strut-rod bushings, what else would you do while it's all dangling?
control arms & bushings?
also, has anyone had any luck pressing out the balljoints?
Old 12-28-12, 04:51 PM
Kansas
Kansas's Avatar
How many miles are on your 99? What should be done depends on what is worn or wearing out.
The front suspension on my similar 2000 LS400 is vastly less troublesome than that on the 1990 LS400 I drove from new to 183,500 miles.
The only front suspension parts that have needed replacing on my 2000 LS400, which is now at 160,000 miles, have been the strut bars and bushings. By 160,000 miles on my 90 LS, the front suspension had been substantially rebuilt with new control arms, bushings and ball joints.
Replace parts only if they are worn out ... no need to flush money away on these cars.
Old 12-28-12, 06:02 PM
Lavrishevo
Lavrishevo's Avatar
A good mechanic can test the control arms for movement. I am in the process of doing all my bushes on my 99. Strut bars have already been done. You can get those from Lexus. Otherwise, if yours are worn then my recommendation is this. Factory upper control arms or the better aftermarket ones. Roca lower control arm bushings. Have the uppers replaced and the lowers pressed.
For the rears, use the Adus 505/5056 kit. This is what I am doing. My car has seen rough road and the suspension has worn harder.
Old 01-03-13, 06:23 PM
steedls400
steedls400's Avatar
Thanks for all the input! I had a look at the suspension while on the lift... It was suggested to me to replace the inner and outer tie rods too.I will be repairing both sides of the front suspension including struts, strut rod bushing and tie rods. DIY or Shop? Would it be any different than a 92? http://www.lexls.com/tutorials/suspe...flowerarm.html
Old 01-03-13, 07:17 PM
Lavrishevo
Lavrishevo's Avatar
Check out these guys.
http://www.armstrongdistributors.com/lexus.html
All these are polyurethane bushings. OK for the rear but not recommended for the front. Try to stay factory / urethane bushes on the front. Poly in the front ruins the ride. Looks like Roca does not supply your year. If your struts are old I would do them too.
Old 01-10-13, 10:31 PM
steedls400
steedls400's Avatar
Thumbs down
I just received my order of KYB front struts from StockWise. Unfortunately they sent me one EXCEL-G (Black) and one GR-2 (silver). Order placed on 01/04 received 01/10 ground shipping. Total $150.19 USD. I was disappointed they would do that so I inquired, they responded it was the only two they had in stock and offered to pay for half the shipping to ship on back without offering a replacement I've decided to keep both and have them installed ASAP as I don't want to continue driving on damaged suspension. Good thing is my mechanic will start the repairs first thing in the a.m.!
Old 01-13-13, 08:40 PM
steedls400
steedls400's Avatar
Had the front struts replaced with KYB excel/GR2 and the passenger inner/outer tie rods replaced with MOOG along with an alignment. The clunking sounding is gone and also drives very smooth. parts $300/ labor $300
Quick Reply: Where to buy OEM struts for '99 LS400?
