Car Hesitating When I try to Accelerate
Old 06-28-12, 04:12 PM
josephgary
josephgary's Avatar
Default Car Hesitating When I try to Accelerate
I have a 1994 Lexus LS 400 with 242,900 miles on it and the car keeps hesitating when I try to accelerate. It will get up to speed if I barely press the pedal, but I'm afraid to even pull out in traffic going 15 mph! I have changed the plugs and wires, tried fuel injection cleaner, cleaned the MAF Sensor, I don't know what to do can someone please help me out!
Old 06-28-12, 04:58 PM
RA010623
RA010623's Avatar
any cel codes?
Old 06-28-12, 05:19 PM
cobalt91
cobalt91's Avatar
Check for vacume leaks. also how is the idle? Does the exhaust smell like raw gas? What did the spark plugs look like?
Old 06-28-12, 05:29 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
try cleaning the TPS.
may be exhaust leak
Old 06-28-12, 07:28 PM
cobalt91
cobalt91's Avatar
I had a similar problem when I bought mine. I went though the ignition (3 bad leads) replaced ect (cracked connecter) and replaced timing belt (off 2 teeth). Hope this helps.
Old 06-29-12, 06:11 AM
Luxurexus
Luxurexus's Avatar
Had a similar problem a few months ago, ended up being the coil packs. Mainly the one below the battery tray. Good luck.
Old 06-29-12, 09:48 AM
josephgary
josephgary's Avatar
no cel codes, check engine flashes on then goes back off and doesn't store any codes. The spark plugs were burned pretty clean. I think i'm going to try the coil packs next. I found a vaccuum leak going to repair that today and if that doesn't do it im trying the coils next.
Old 06-29-12, 01:36 PM
josephgary
josephgary's Avatar
By the way the idle is terrible is at about 600rpm. That vacuum hose did not fix it.
Old 06-29-12, 01:40 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
did you try cleaning the MAF, TPS, or throttle body?
all of these contribute problems if not cleaned for a while.
Old 06-30-12, 07:21 AM
deanshark
deanshark's Avatar
The RPM is supposed to be at 600 give or take 50. What happens if you have it in Park and slam the gas? Does the RPM go up or stop at a certain point, such as 2500? I think you should check the coils, starting with the driver's side.
Old 06-30-12, 01:02 PM
OKSTANCE
OKSTANCE's Avatar
mine does the same thing. its a 93 with 126k
i was told i have an exhaust leak so MAYBE thats it...i haven't got to address the issue yet
Old 07-02-12, 01:11 PM
josephgary
josephgary's Avatar
[QUOTE=deanshark;7329315]The RPM is supposed to be at 600 give or take 50. What happens if you have it in Park and slam the gas? Does the RPM go up or stop at a certain point, such as 2500? I think you should check the coils, starting with the driver's side. When in park it does go up it doesn't stop. Just when I'm
driving it acts like it doesn't have any power. I ordered a new coil for the driver's side. I'm gonna see if that works.
Old 07-06-12, 12:30 PM
josephgary
josephgary's Avatar
Update on my lex I put in the drivers side coil and no change at all. I cleaned the MAF gonna try the throttle body this weekend and replace the other coil I guess. Any suggestions?
Old 07-06-12, 12:51 PM
j2b4o
j2b4o's Avatar
I once cleaned my MAF and posted about it and several people said that the MAF on the 1st gens shouldn't be cleaned and that cleaning it could ruin it. Mine was fine after the clean but there may be something wrong with your MAF because it can cause these symptoms. I would expect I to cause a CEL though.
Old 07-06-12, 02:59 PM
josephgary
josephgary's Avatar
Oh wow I wasn't told that! that could be an issue it isn't throwing a check engine light but it is running very rough. I guess I'm going to need one of those also.
Posted from ClubLexus.com App for Android
Quick Reply: Car Hesitating When I try to Accelerate
