Headlight Problem
Old 06-25-12, 02:03 AM
nordoyan
nordoyan's Avatar
Default Headlight Problem
I have a 99 LS4, i had an accident with the car airbags opened up. the body shop messed up my car big time i really don't want to get into specifics.
when i turn my headlights on auto, it doesn't work that is my first problem
my second problem is that when i use high beams flash or pushed back my DRL turn on instead and the High Beam light on the dash doesn't come up any suggestions
thanks in advance
Old 06-25-12, 11:44 AM
RA40
Super Moderator
RA40's Avatar
A multitude of possibilities. How much damage to the front did your car sustain? Is your car HID equipped? What did they fix? I suspect a short simply, now finding it may not be easy. Check the headlight harness on the side that was repaired first.
Old 06-27-12, 04:46 PM
Kalaries
Kalaries's Avatar
i agree, its a little hard to figure out if you dont want to go into specifics.... knowing what they fixed is a big part of it,
judging off your profile picture i would assume you have HIDs, they may have replaced your lights with a different kit or not installed it correctly or left out a relay which sometimes causes wierd problems like that. But once again we dont know what they fixed, so mine are all just guesses.
-Body Shop Manager
Drofseh
SC- 1st Gen (1992-2000)
06-10-16 01:42 PM
jeanphil99
04-07-15 01:36 PM
snook
20
06-11-13 07:17 AM
MIDO
12-28-09 02:31 PM
FWCruiser
10-18-03 06:00 AM
Quick Reply: Headlight Problem
