LS400 California smog test worries
Old 06-13-12, 12:50 PM
fuzzygrape
fuzzygrape's Avatar
Default LS400 California smog test worries
Hello! It looks like I'm going to be obtaining an 1998 LS400 from out of state to California as a family gift, but I'm a little worried about it failing the smog emissions test.
Is there anything I should do prior to getting it smogged to 'prep' it? Does a decently maintained LS400 usually pass? Thanks!
Old 06-13-12, 04:03 PM
SpencerT
SpencerT's Avatar
Exhuast leaks right after the catalytic converters due to rusty flanges and aging gaskets are fairly common.
Other than that, Im not sure.
Fairly certain the 98 was the first ls classified as an ulev (ultra low emmisions vehicle) though so you might have a decent chance.
Old 06-13-12, 04:05 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
if nothing's broken and there's no CELs it should pass just fine.
Old 06-13-12, 04:50 PM
clipster
clipster's Avatar
Default I'll counter that idea
It all depends on the mileage.
I have a 98 that I bought in 04 with 70K and today its at 180K. 3 checks ago I came very close to failing due to high NOx, which had been trending upward with each check. For the last two checks I've done everything I can before the test to keep the number down - check plugs, clean throttle body, replace air filters, fresh fuel and oil, then driven hard for 100 miles right before going in for the test. This has kept my NOx from rising any further and therefore continuing to pass.
Strangely, I've gotten better numbers from the shops where I paid a lot (>$50) for the test. Maybe they do a better job of cleaning the testing equipment?
Old 06-14-12, 09:13 AM
bauceLS400
bauceLS400's Avatar
No worries, just make sure your Cats are warmed up. It should be okay.
Old 06-14-12, 10:48 AM
91LS400vgb
91LS400vgb's Avatar
If your NOx's are trending higher, then it most likely indicates that the EGR exhaust gases reaching your intake are reduced, though not enough for it to fail or throw a code. The most likely cause of this is carbon buildup in the EGR valve or in the passages before or after the valve. I would spend the time to clean everything out before your next inspection and see if it improves.
Old 06-14-12, 02:59 PM
PureDrifter
BahHumBug
'98-00 don't have EGRs. they can use the VVTi at certain engine speeds to open the intake valves slightly earlier, mixing gases.
your NOx will ALWAYS be higher when you don't properly warm up the cats.
Old 06-14-12, 05:17 PM
timmy0tool
timmy0tool's Avatar
i never knew this. so you 98-ups don't have that pesky EGR tube leak!? so lucky!
Old 06-14-12, 09:53 PM
fuzzygrape
fuzzygrape's Avatar
Thanks everyone!!! It's a pretty sweet car so I'm happy to have it... just was a little nervous about the smog test. I'm feeling much better now, will drive it around 20-30 mins prior to going to the place to warm it up a bit.
AFAIK the mileage is around 130k, by the way.
I'm going to try to take it to one of those "free retest" places so if it fails on first try I won't freak. Hopefully even if it doesn't pass it just might need some minor catch up maintenance.
Old 06-15-12, 05:35 AM
91LS400vgb
91LS400vgb's Avatar
Oops, I didn't realize that was already implemented by 98. Thanks, PD.
Old 06-16-12, 05:57 PM
fuzzygrape
fuzzygrape's Avatar
It PASSED! Whoo hoo!!
Thanks everyone! It did pretty well too. If anyone cares/is curious I can post the numbers.
Old 06-16-12, 06:15 PM
SpencerT
SpencerT's Avatar
You should do that. Im pretty curious even though they dont smog test where I live
Old 06-16-12, 07:11 PM
RA40
Super Moderator
RA40's Avatar
Congrats on passing. Which state was the car originating from? Yes, please post the readings.
CA emissions have become more strict over the years. For older cars the restricted standards make it tough. Most properly running LS's should clear without issue.
Old 06-16-12, 08:27 PM
fuzzygrape
fuzzygrape's Avatar
The car is being transferred from Florida.
Here's the emissions stats:
%CO2
14.9 (both speeds)
%O2
0.0 (both speeds)
HC (PPM)
15 MPH - 21
25 MPH - 16
CO (%)
15 MPH - 0.04
25 MPH - 0.06
NO (PPM)
15 MPH - 287
25 MPH - 89
andlours
36
05-11-19 11:00 PM
Juelz21
13
11-19-18 07:46 PM
Aristsojzs
12-04-16 10:34 AM
cgreenberg
14
03-23-14 09:47 AM
LSpho
57
03-13-14 12:04 PM
Quick Reply: LS400 California smog test worries
