Check Engine Light - Is it worth keeping LS 400?
Old 04-30-12, 07:08 AM
ls400rgr
ls400rgr's Avatar
Cool Check Engine Light - Is it worth keeping LS 400?
ok -
1999 LS 400 with 299,200 miles. Check engine light has been on for 2+ years, but Florida does not require emission test (hey a year in Afghanistan I other things to worry about than a check engine light). Now back in Connecticut which does. Connecticut emissions will fail you if check engine light is on, irregardless of the actual emission reading. So you have to clear the code. (Yes I did try disconnecting battery ect)
Dealer says it is a hard code error on 3 gear solenoid. Recommends drop tranmission replace solenoid. - $1000 with part. 90% of time it will correct issue.
Engine still runs great.
Anyone else have similar issue? How resolved?
Or should I cash in my chips for a '08 LS 460?
Old 04-30-12, 09:55 AM
GS4_Fiend
GS4_Fiend's Avatar
Look for the DLC connector in the engine compartment. And use a papet clip and jump pin TE1 and E1 and count the check engine light flashes.
Old 04-30-12, 11:18 AM
ls400rgr
ls400rgr's Avatar
OK-i'm a bit ignorant here, what will that tell me?
Old 04-30-12, 12:50 PM
GS4_Fiend
GS4_Fiend's Avatar
The codes.
Old 04-30-12, 12:52 PM
Bradster
Bradster's Avatar
It's a 1999
Old 04-30-12, 01:37 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
that only works for pre '95 LS400s with OBDI....
OP, the trans doesnt need to be dropped for solenoid replacement. find a trustworthy independent and get a 2nd opinion.
Old 04-30-12, 02:16 PM
GS4_Fiend
GS4_Fiend's Avatar
Originally Posted by Bradster
It's a 1999
Didnt see that sorry. Get it scanned then
Old 04-30-12, 02:37 PM
ls400rgr
ls400rgr's Avatar
The code comes up as a third gear solenoid error. Dealer tried sending a message thru to re-activate... no luck. He has been very fair with me through the years.
Said if solenoid doesn't work could need to replace ECM - another $1500 - ugh
Would a nation chain like MAACO be a good option for 2d opinion?
Old 04-30-12, 07:50 PM
PureDrifter
BahHumBug
no. i would recco looking in the regional forums for a good independent.
I had a solenoid and harness replaced right when I got my LS years and years ago and at a quality indpt. i was in for WAY less than what you're talking about. the trans pan needs to be dropped, nothing else.
Your dealer sounds sketch because he's tallking about doing a $1000+ service that MAY fix the problem, if not you need a $1500 ECU?? and you think he's being fair? lol.
regional forums:
https://www.clublexus.com/forums/northeast-21/
https://www.clublexus.com/forums/neloc-175/
Old 05-01-12, 05:30 AM
ls400rgr
ls400rgr's Avatar
regional forums:
Spoke with local independent guy I have used before, he has been more than fair with me in the past and will give me an 2nd look. The engine still runs great and I average 26-28 mpg in summer, 22-24 in winter. Has a few cosmetic dings with 299+ miles and 3 kids who drive.Looking for excuse to keep it. Thx
Old 05-01-12, 03:09 PM
PureDrifter
BahHumBug
good luck, find out the actual OBDII error code and post it up here to get another opinion (searching on it too is recco'd).
Old 05-01-12, 06:03 PM
ls400rgr
ls400rgr's Avatar
Looking at my invoice
"Diag , p0763 , needs a #3 shift sol."
"00989 DIAG to find vehicle will need transmission shift solenoid ($1050)
Make sense to anyone?
Old 05-01-12, 09:49 PM
PureDrifter
BahHumBug
could very easily be the harness for the solenoid, as when its the solenoid itself you lose use of 1 or more gears.
Old 05-02-12, 08:29 AM
ls400rgr
ls400rgr's Avatar
Is there a method to test if it is the harness?
Old 05-02-12, 02:25 PM
steve2006
steve2006's Avatar
Good write up on replacing shift solenoids here including the 63 code you are having and not costing over $1000.00.
https://www.clublexus.com/forums/sc-...placement.html
Quick Reply: Check Engine Light - Is it worth keeping LS 400?
