Need HELP diagnosing transmission problem
Old 04-25-12, 12:07 PM
Luxurexus
Luxurexus's Avatar
Default Need HELP diagnosing transmission problem
So today I start my '91 LS400 and the transmission button is stuck and will not allow me to shift thru any gears. After hitting the shift lock over ride button it went back to working perfectly. Now every time I turn off and restart the car I have to press the Shift Lock Over Ride button. What causes this? I have about 200,xxx miles and am not sure what fluid is currently in it or how old it is because it is a recently purchased vehicle. The fluid still looks red in color but is a little dirty. Any and all help is appreciated.
Old 04-26-12, 10:36 AM
Luxurexus
Luxurexus's Avatar
Has anyone else heard of or had this problem? I am going to attempt to change the fluid and filter to see if it makes a difference but would rather not waste the $100 if it is a new transmission I need.
Old 04-26-12, 10:48 AM
SpencerT
SpencerT's Avatar
If it returns to normal after you hit the shift lock, I doubt you need a new transmission.
Old 04-26-12, 11:56 AM
Luxurexus
Luxurexus's Avatar
I hope not, but why is it getting locked up? I can understand it locking up from time to time but with it being every time it makes me think there is something wrong.
Old 04-26-12, 05:02 PM
SpencerT
SpencerT's Avatar
After some research:
In order to move the shift lever out of park, the key must be turned to acessory or on and the brake pedal must be depressed. When this happens the ECU turns on the shift lock solenoid, moving the plate stopper and allowing the shift lock plate to move into position.
If the solenoid becomes inoperative, the shift lever cannot be moved. The shift lock overide button can be pressed to manually release the plate stopper from the shift lock plate, allowing you to shift.
Sounds like its the shift lock solenoid to me.
This is a generic toyota diagram and should clarify what I said before
Old 04-27-12, 12:31 PM
steve2006
steve2006's Avatar
I've seen this problem before, over the years all sorts of dirt and crud falls into the selector, giving it a good cleanout with a vacuum and brush normally frees things off again.
With the ignition on put your foot on the brake pedal and you should be able to hear and feel the solenoid operate, if you can't try the above suggestion.
Old 04-27-12, 04:38 PM
Luxurexus
Luxurexus's Avatar
Thanks Spencer your a life saver. I tried cleaning out everything today but did not have this diagram, I will retry in the morning and try and target the important areas.
Old 04-27-12, 06:04 PM
SpencerT
SpencerT's Avatar
Not a problem.
here is my source if what I gave you isnt enough.
http://www.autoshop101.com/forms/h18.pdf
good luck
DarkMan25
08-26-16 11:12 AM
lserlohn
RX - 1st Gen (1999-2003)
41
06-06-16 05:45 PM
lexus-is2
12-03-14 01:51 PM
Lexus813
15
10-13-13 07:44 AM
MellonC00
08-05-05 10:56 AM
Quick Reply: Need HELP diagnosing transmission problem
