Tires with g35 rims
Old 04-29-12, 10:01 PM
Greyhorne
Greyhorne's Avatar
Would running a 50 side wall be to much? I don't care as much about the the look, mostly I don't want my ride compromised but I would like a little better handling.The ride being paramount.
Old 04-29-12, 11:07 PM
RA40
Super Moderator
RA40's Avatar
There isa tire size calculator in the UCF2X FAQ that will show diameter and associated speedo info for the given choices. Play away:
http://www.anycalculator.com/tiresize.htm
Old 04-30-12, 09:28 AM
bauceLS400
bauceLS400's Avatar
Hey just a quick question. what hub centric rings will i need for the g35 wheels?
Old 04-30-12, 11:05 AM
xtremex626
xtremex626's Avatar
50 tire wall wouldn't be too much. if you're all for ride comfort, then go for it but 45 is good enough.\
lexus bore is 60.1 , infiniti is 66.1
i got the $10 plastic hubcentric rings off of ebay. they've been working fine so far. had them for 5+ months.
Old 04-30-12, 04:53 PM
bauceLS400
bauceLS400's Avatar
Awesome! i just ordered them. Thanks for the info.
Old 05-25-13, 07:20 PM
yawra
yawra's Avatar
Originally Posted by xtremex626
way more than enough clearance with these g35 18" wheels. more clearance than our stock LS wheels too.
clearance check for you
you should run a 225/45/18 all around if you want the stock feel (g35's run 225/45/18 in the front and 245/45/18 in the rear for stock). i ran a 40 series sidewall because i don't want the fat tire look and 35 series on an 18" just looks too small/thin and i'd be on the floor with those.
Im actually picking up some g35's as well except there 17x7 I have a 93 ls400 and I was wondering if they'd clear the breaks on it?
Old 05-25-13, 07:27 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
1st gen LS' have puny stock brakes, you'll be fine.
Old 03-04-14, 08:34 PM
mccrimmon
mccrimmon's Avatar
SUPER old thread I know, sorry! I was just wondering if xtreme was running any spacers with the G35's. PM sent, just covering all bases.
Dreamer777
RX - 3rd Gen (2010-2015)
09-14-18 07:04 AM
geovanilop
Wheels, Tires & Brakes Forum
04-24-17 12:43 PM
2000 ls400
03-24-10 07:41 PM
sonbum1
06-23-05 04:56 PM
GSXRAWD
09-17-01 12:27 PM
Quick Reply: Tires with g35 rims
