Knock Sensor Replacement
Old 03-26-12, 09:31 AM
crcuevas
crcuevas's Avatar
Default Knock Sensor Replacement
Hi All,
I just did my knock sensor replacement. It took two weekends But now when i start the car it runs fine until I rev it up to around 1600 to 1800 RPM and it acts like it wants to die. I can't rev up pass 1800 rpm. Reason why I replaced both knock sensors had a squirrel or a rat chew thru one of the knock sensor wire so I decided to replace both. That was a job!
But now I can't rev pass 1800 rpm!!!!!
Any ideas? Did I miss something? Also, I have NO check engine light!!! I use to have error code 52.
Chuck
Old 03-26-12, 02:19 PM
crcuevas
crcuevas's Avatar
Ok, Does anyone have any idea why my car dies pass 1800 rpm? any help please!!!!
Old 03-26-12, 02:25 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
no idea but posting the year of your car generally helps a lot...
Old 03-26-12, 03:05 PM
crcuevas
crcuevas's Avatar
Sorry all. 1994 with 230K miles.
Old 03-26-12, 04:03 PM
dashan
dashan's Avatar
check Mass Air Flow Meter.
Old 03-27-12, 06:01 AM
python
python's Avatar
u only did 1 sensor? did u change the connectors also? posting before u do the work would have been advantageous..personally i would have also did the starter
Old 03-27-12, 09:11 AM
crcuevas
crcuevas's Avatar
I did both knock sensors. i bought the connector but they send me the wrong one. I have a Cali car and it requires a different type so i spliced the connector to the old one. Would that cause the problem?
It wasn't as hard as it seems, just very time consuming.
Also, replaced Mass Flow Meter. That the was first thing I did before replacing the knock sensors.
Old 03-27-12, 04:29 PM
firefinder
firefinder's Avatar
try rebooting all electronics by taking battery terminals out for a few minutes.
Old 03-28-12, 09:17 AM
crcuevas
crcuevas's Avatar
I will try that. Just FYI, the battery was already discounted for the two weekends that I worked on the car. But you'll never know!
What's really odd is that I have no codes. You would think I would get something.
Old 03-28-12, 04:52 PM
LScowboyLS
LScowboyLS's Avatar
I sure hope you replaced your starter while you were in there, that job is such a pain that I consider that if a starter or knock sensor needs replacement, that you never do one with out doing the other, since you are already there!
Old 03-28-12, 04:55 PM
LScowboyLS
LScowboyLS's Avatar
also make sure the battery is new condition and fully charged, sometimes my LS will run bad when the battery gets old or somewhat discharged, they seem to be sensitive about this
Old 04-02-12, 06:28 AM
crcuevas
crcuevas's Avatar
Well this weekend I checked my LS to see if I can find out what's causing this problem. I've noticed if I rev it up slow I can pass the 1800rpm and go beyond. But if I do it fast, rev it up that is, it sputters and wants to die. Also my alternator just died. Don't know why. This is very frustrating.
Old 09-22-19, 11:04 AM
Sherl
Sherl's Avatar
What did you end up doing? I have CA car 98 LS400 and looking to replace knock sensors as well.
Bluv
11-09-15 01:28 PM
g35c
11-23-10 12:33 AM
Garymkrieg
RX - 1st Gen (1999-2003)
07-17-06 11:02 AM
Quick Reply: Knock Sensor Replacement
