Purchase Advice???
Old 03-04-12, 04:17 PM
jstyles129
jstyles129's Avatar
Default Purchase Advice???
Im looking at a 96 LS400 with 120,000 miles on it. Its also a one owner with all the records for it. Timeing belt and everything has been changedand It drives very very well. The problem that it has is when you shift it into drive when its cold it takes a while for it to shift into gear. Im not sure if the trans is shoot or what but after it heats up it runs smooth as silk. Hes only askink 3500 for the car and I just wanted you guys feedback if possible. Thanks in advance.
Old 03-04-12, 04:30 PM
jerryparks
jerryparks's Avatar
Default trans issue
I have a '92 LS400 that does the same thing. I read in an earlier post that this is normal on these cars. After the trans warms up, its good to go for the reat of the day. That is also a good price on the car, especially with all the maint records up to date,
Old 03-04-12, 04:43 PM
Lavrishevo
Lavrishevo's Avatar
Check this thread out:
https://www.clublexus.com/forums/per...-going-on.html
Old 03-06-12, 06:54 AM
BobN54
BobN54's Avatar
I would not be afraid of it unless you find the fluid to be dark brown and smelly. Try an fluid flush and clean the filter screen. Aisin transmissions of that vintage are not the smoothest operating devices on the planet when cold. Worst case, you are looking a installing a used ATX sometime in the future. Maybe he will come down to $3K if you point out the problem.
DVL5WRK95
04-05-24 09:01 PM
fordstone
05-27-19 04:27 PM
VIP40092
08-30-15 11:14 PM
DanaL52
02-27-14 12:08 AM
rcltrh
06-23-02 05:56 PM
Quick Reply: Purchase Advice???
